Staintune map can't be loaded on my 2001 Vfr
Discussion in '5th Generation 1998-2001' started by BOSUNCHAIRMAN, May 17, 2017.
  1. BOSUNCHAIRMAN
    BOSUNCHAIRMAN New Member
    Wabamun Alberta
    Hi guys. I'm ready to lose it. Just bought a staintune low mount pipe at great expense and I can't load the staintune map I downloaded from the power commander site. Btw I'm using a PClll-USB. I've been running the 106-301 map all last year with no problems btw. What gives? The software doesn't recognize the staintune file. I'm sure some one has gone through this crap as well. I just want the right map for the bike. It's a 2001 Canadian VFR with a K&N and that's it. Seems like there's only half a dozen files I have to choose from. Sent an email to Dynojet but I don't have much hope from them.
  2. OOTV
    OOTV Well-Known Member
    Which Power Commander do you have?
  3. RVFR
    RVFR Well-Known Member
    Ah...It's best to just get a dyno tune and have your own map.
  4. vegaquark
    vegaquark Active Member
    Spain
    Spain
    I'll buy you that power commander to test it if you give up
    Should be straightforward afaik
  5. RVFR
    Back a couple years just proir to me finding a PC3, I looked over the maps Dyno jet had in store, and there where maybe like 3 that may apply to what I had. They where pretty generic, so figured what the hey, I've gone this far might as well do it right, no second guessing, so threw the VFR on a dyno.. wa la. well worth the money. But now seeing where you're at, not sure how possible and troublesome that could be. Still way worth it.
    dhinson66 likes this.
