Stator cover oil leak.
Discussion in 'Mechanics Garage' started by mofo, Feb 12, 2018.
  1. mofo
    mofo New Member
    Orange County Ca.
    I replaced the stator and rectifier last year and over time, the stator cover developed a leak.
    Since there is an OEM gasket there, common sense dictates that I should replace it with another one but wondering if I can use silicone instead?
    Has anyone used silicone instead before? Any pros or cons about using OEM gasket or silicone?
    if the gasket is not missing pieces, you can try a fix with that +sillycone or other sealers. ;)
    you'll need to inspect closely for any nicks, dents, or deep scratches on the cover and its mating surface on the block.
    i had a slow stator cover oil leak on one of my '86 700's that eventually caused the radiator hose running under it to deteriorate to the point of failure and sudden water loss....:eek:
  3. mello dude
  4. OOTV
    OOTV Insider
    Permatex, Honda Bond, all work well. I had replaced my stator and somehow the gasket got tweaked and oil started leaking. Not wanting to wait for another gasket to arrive, used some Honda Bond and all was good!
  5. mofo
    mofo New Member
    Orange County Ca.
    Exactly what I'm trying to avoid.
  6. mofo
    mofo New Member
    Orange County Ca.
    Thanks fellas. I'll look into those.
  7. 34468 Randy
    SQ's water broke LOL
  8. squirrelman
    Right, a little oil leak caused a sudden big coolant leak.
