Tappered Head Bearings 4 Gen How to
Discussion in 'Mechanics Garage' started by SLOVFR, Feb 22, 2009.
  1. SLOVFR
    SLOVFR Well-Known Member
    Lompoc Ca.
    Well I have not heard or seen one All Balls Bearing kit fail yet. If you have any proof please post up. If you think you have a better and cheaper solution then please post relevant part numbers so all can share. Otherwise I would not hesitate to recommend the kit to anybody. The grease you use is far more important in a bearing then the actual bearing in most cases and Im sure Alls Balls is not going to risk their company by selling second rate bearings.
  2. jaimev34
    jaimev34 New Member
    Oceanside, Ca
    I haven't checked the service manual yet; does it explain the entire process (head bearing removal/assembly) in detail? I'm not as mechanically experienced as others and was wondering if it has more in-depth instructions, not that SLOVFR's aren't great. My bike has 38k miles and I'm doing all the maintenance (e.g., valve check, spark plug inspection, head bearing replacement, and probably coolant flush and brake fluid replacement) this month.
  3. squirrelman
    squirrelman Well-Known Member
    At 38k you're probably due for bearing replacement, both headset bearings AND wheel bearings.
    don't cheap out with chinese junk like Allballs; QUALITY bearings come from USA, Japan, or Germany ONLY.
  4. jaimev34
    jaimev34 New Member
    Oceanside, Ca
    Do you have any suggestions or links? A lot of people use All Balls and like them. Have you heard anything bad about them, or do you simply not trust Chinese quality?
  5. squirrelman
    Chinese haven't yet figured out quality control; just look carefully at any Chinese-made scooter.
    They only make things aimed at the lowest price possible, and you get what you pay for.
  6. SLOVFR
    Lompoc Ca.
    Why dont you tell that to my Chinese girlfriends parents :tongue:
  7. Ozwanderer
    Ozwanderer New Member
    Coffs Harbour, NSW
    G'day guys
    Did anybody happen to get the numbers off the tapered races (inner and outer, top and bottom) before installing them?... that way I can order NSK or Timkens from my local bearing supplier 'at the right price'
    and.. are the new seals in the kit the same as the OEM seals?
    I have a '95 Gen 4 with 76k Kilometers on the clock... and sometimes when stopping firmly, or with pillion, I get a click click from the steering head as I pull up and the weight comes off
    Cheers
    Laurie
  8. Rchecks
    Rchecks New Member
    Summerville, SC
    the ALL Balls Set I got for my 4th Gen has a 32006X and 32005X KLM bearings
    32006X
    32005X
  9. Ozwanderer
    Coffs Harbour, NSW
    Thanks Rchecks
    Armed with this info, I'll go hunting.. :)
    Cheers
  10. SLOVFR
    Lompoc Ca.
