Throttle Problem
Discussion in 'Mechanics Garage' started by Guest, Jan 25, 2004.
  1. Guest
    Guest Guest
    need some advice.
    my throttle clip on broke so i replaced the whole thing.
    now the clip-on is the aluminum part of the whole handle bar assembly.the aluminum part goes into the throttle and then the switch clips onto the clip-on. but now for some reason once everything is locked in place my throttle has become extremely hard to twist. it does not go back. how do i fix this problem.
    thanks
    Russ
  2. Guest
    Guest Guest
    problem FIXED. needed grease :-/ and an adjustment to the throttle cable screws near the switch. it required the screw ot be adjusted a bit for soft cable return response. confusing... ???..i understand
    THANKS!!!
