Top 3 "must knows" for new vfr owner
Discussion in '7th Generation 2010-Present' started by Tyler8pitch, Oct 14, 2016.
  1. Tyler8pitch
    Tyler8pitch New Member
    Charlotte NC
    Hi all. Two things just happened. 1- I just bought a 2010 vfr1200f with 3,000 miles. And 2- I just discovered this forum! I think I scored a time capsule and plan to sort through the bike in the next few weeks. At first glance it seems to be pristine and I was told it had the factory drive shaft recall repair performed. So here's the 100M dollar question. As a new vfr owner, what are your top three must knows about this bike? The must knows can be mechanical suggestions, maintenance related or suggestions as to how to wipe that silly grin off your face. All opinions help! Cheers [​IMG]
    Trakrat likes this.
  2. MarkinReno
    MarkinReno New Member
    Reno, NV
    If your new vfr has the original tires, change them both. Set the suspension on the firm side, spring rate and damping. Get the Guhl reflash.
    Sent from my SM-G930P using Tapatalk
    Trakrat likes this.
  3. MarkinReno
    Reno, NV
    Trakrat likes this.
  4. GigemVFR
    GigemVFR New Member
    TEXAS
    Do not use K&N oil filters.
    Lots of people having problems with them leaking or blowing out going down the road. Other filters are okay.
  5. James Bond
    James Bond New Member
    Dixie
    Don't know about your version of a VFR. I have the 8th gen.
    You must know that all cages are there to kill you. Ride accordingly.
    If you haven't ridden much, or if you have, read some books by Keith Code and others and learn the physics riding and you'll be a better rider.
    Use real gasoline not ethanol gas.
    Ro Dento likes this.
  6. Tyler8pitch
    Charlotte NC
    Thanks all for the recommendations so far. Keep them coming! The guhl sounds interesting. I'll look into it. New tires are on the bike. I couldn't agree more on Keith Code. I read the book many years ago, always helpful for a refresh. I was previously riding a thruxton. In addition I have a track only sv650. I took the vfr out for my first ride this afternoon.. The power transforms my perception of speed as compared to the sv and thrux. It's pretty amazing but you guys already know that!
  7. Badbilly
    Velo or Triumph Thruxton?
    Billtr96sn likes this.
  8. Tyler8pitch
    Charlotte NC
    Thruxton with an arrow exhaust and the tpusa high compression kit. Very happy with the bike but the wind and twin beat me up on long trips. Hence the move to a vfr
    Sent from my iPad using Tapatalk
  9. ozzybob
    ozzybob New Member
    If you are running the standard pipe disconnect the cable on the servo motor and the quiet flap will stay open. [​IMG]notice I also cut the cross wires out.
  10. nic579
    nic579 New Member
    I have to say that mine had the stock tires and was setup with the suspension on the hard side and it handled for shit like that. I did a fork oil job on the forks at the stock level in service manual and left the spring adjusters all the way out and now "Before the van backed into and destroyed the forks and triples" the bike turned in much better and had good feel and braking confidence.
    I do have Continental Road Attack 2 EVO set ready to go on the bike when the front end is back in place.
    Were the forks more firm "firm is vague what does that actually tell anyone?" than yours? Hard to say.
    As far as I can tell with the rear end at least the stock spring needs to go and possibly the whole shock. The shock is adequate and works taking the bike up in excess of any road legal speeds but is not very compliant and comfortable in ride. I am looking at the Ohlins fork valving for stock forks "dampening and rebound adjustable" and possibly the rear shock. its something like $1200 for the whole shebang.
    The first and second gear restrictions need to be removed if they are still in place they make for an odd surging issue in some cases at slow speeds that I found to be dangerous. I got the Bazzaz Z-Bomb dongle. Or get ecu re-flash.
  11. MarkinReno
    Reno, NV
    My 2013 had the original Bridgestones with 3500 miles and plenty of tread. The handling was evil.No amount of suspension tweaking would correct the handling issues that were corrected by a simple change to premium sport touring tires. The bike has been ridden 13k miles this year from Death Valley to Prince Rupert, BC. Few freeways and minimal chicken strips.
  12. ozzybob
    ozzybob New Member
    Mine has Dunlop sport smart which feels great.
    [​IMG]the bike is 1050km old.
    Off on a 2500km round trip to MotoGP at Phillip island on Wednesday. Can't bloody wait.
  13. MarkinReno
    Reno, NV
    I find firm to be only in the adjustment range. Subjectively, the spring feels quite soft and compliant hence the increased damping setting.
  14. MarkinReno
    Reno, NV
  15. Glenngt750
    Glenngt750 New Member
    Edmonton, Alberta, Canada
    Yeh, I am soooo bummed that it snowed here, a bit, AND you're telling me you are going to a F@#$%&^g GP!!!! Cheers,Mate!
  16. ozzybob
    ozzybob New Member
    Yes in 17 hours and 29 minutes. Not that I'm counting or anything.
  17. marriedman
    marriedman New Member
    Dayton, OH
    The 7th gen is an incredible bike, the power is intoxicating to say the least and it handles fantastic for a bike of it's size. After acclimating to the power, the Don Guhl ECU flash makes it even better! The only gripes I have with the bike is the fairings. Most people seem to have no problem getting them off and on, but they are my nemesis and I hate them. Love the look, hate the method. So I would recommend taking your time. Really take your time!
    The OEM exhaust is a boat anchor, find another one ASAP. The sound of the DAM exhaust is the one that I liked best and ended up with eventually. I would save you the money of trying others first.
    A fuse block is a good idea if you are going to add any farkles like GPS, cell phone charger, heated grips, pigtail, and etc... Other than that, she's good to go!
  18. Tyler8pitch
    Charlotte NC
    Excellent suggestions! I agree,,, plenty of power but I love any recommendation which includes improving handling, throttle response and weight savings. I'll do some research on the dam. Would love to know how much weight it would save...
  19. ozzybob
    ozzybob New Member
    This is the arrow pipe I'm going with, IMO it's better looking than the DAM and claims to be lighter and have numbers than an akrapovic [​IMG]
  20. ozzybob
    ozzybob New Member
    The fairings aren't that hard to get off when you know how, Pricks to get back on however, the side panels are almost a 2 man job.
    I'm dreading it when I have to get to the plugs to fit a quick shifter
