VF1000F Coil Replacement
Discussion in 'Mechanics Garage' started by wpbarlow, Nov 8, 2017.
  1. wpbarlow
    wpbarlow New Member
    Central New Jersey
    The coils on my "almost road worthy" other VF have large/long lengthwise cracks.
    Rather than getting used ones, I'd like to source aftermarket ones. I'm hoping someone has done this and can provide some guidance.
    I've seen reference and Tom (of V4Spark) verified that these Accel coils would work.
    https://www.holley.com/products/mot...nition/motorcycle_ignition_coils/parts/140403
    However, I see that the exits of the coils seem to go "up" rather than "back" as the stock ones do. Do they actually get mounted as the stock units, or do they need to be relocated?
    Dyna coils seem to have the same issue.
    http://4into1.com/dynatek-3-ohm-green-coils-dual-output-dc1-1/
    TIA,
    Walter
    I have a VF750F (extremely close to the VF1000F as far as this kind of stuff) for a parts bike that has some Accel's on it from back in the day. They are mounted in the stock location with some custom brackets. I'll post a pic of the brackets and routing later if you like.
  3. wpbarlow
    wpbarlow New Member
    Central New Jersey
    I was thinking today that a set of small 90 degree brackets might work.
    So I'd love to see what your setup looks like.
    Thanks,
    Walter
    Yep... That's exactly what they did. But it might have been a kit, the brackets look better than the usual hack job.
  5. wpbarlow
    wpbarlow New Member
    Central New Jersey
    Your images don't display.
    Sure as shit, when I log out, either can I. Hold on.
    Fixed.
  7. wpbarlow
    wpbarlow New Member
    Central New Jersey
    Thanks very much.
    Walter
  8. slovcan
    slovcan New Member
    Annapolis Valley, NS, Canada - IBA #63720
    That looks neat and tidy. Good job whoever did it.
