VF1000F Right Side Switch Gear
Discussion in '1st & 2nd Generation 1983-1989' started by wpbarlow, Sep 4, 2017.
  1. wpbarlow
    wpbarlow New Member
    Central New Jersey
    The OEM switch, what Honda calls SWITCH ASSY., STARTER STOP 35130-MB6-670, doesn't seem to be available from anyone (I checked a number of likely sources).
    Anyone know if the same switch is used on another model? Not that I expect it to be available new; but it might widen the search for a used one.
    tia,
    Walter
    Don't bother replacing with the same flawed unit. The start buttons will eventually fail. Look for a CBR600F2/F3 style. No real "rewiring" required, you may just have to swap locations of the connectors in the plug to match the bike. I've done it on a couple of mine as well as going with 900RR style individual throttle housing and start switch.
    Disregard if you are going for a perfect restoration.
  3. wpbarlow
    wpbarlow New Member
    Central New Jersey
    LOL, that happened on the bike I just bought. One of the POs installed a push button on the dash. Works fine.
    I didn't realize that was a known issue- no wonder they seem to be rare on ebay.
    Is there a write-up on the repinning?
    tia
    Walter
    You just need a small flat blade screwdriver, like for sunglasses, to release the pin from the connector. Then just put them where they match the wire harness side by color.
  5. wpbarlow
    wpbarlow New Member
    Central New Jersey
    Great- thanks.
    Walter
  6. THRASHED
    THRASHED New Member
    San Dimas, CA
    It seems like I may have the exact same problem with my 87. Any update on how this repair worked for you?
  7. wpbarlow
    wpbarlow New Member
    Central New Jersey
    I haven't replaced the switch as what the PO (a helo mechanic) did still works fine, and will probably outlast the rest of the bike lol
