VF500 fuel mileage
Discussion in '1st & 2nd Generation 1983-1989' started by slowbird, May 3, 2008.
  1. slowbird
    slowbird Member
    Toronto, Ontario.
    Hey there,
    Just curious what everyones VF500's are averaging in their fuel economy?
    i.e kms/miles per Tank
    MPG
    Also...when you switch to reserve how long have you gone? How many litres/Gallons is accessible by reserve?
  2. mls03jbody
    mls03jbody New Member
    Lafayette, Indiana
    I got about 135 miles off almost a full tank and then had to switch to reserve but I never tested my fate and ran on reserve for very long at all
  3. slowbird
    slowbird Member
    Toronto, Ontario.
    Pretty good...comes up to about 31MPG. What kinda of riding do you do? Cruise at high revs?
    Anyone know how at how many Gallons/Liters the reserve is at?
    Interested to see what everyone else is getting...I have yet to use a full Tank on my Bike. Filled it up and have only put on about 160kms.
  4. stewartj239
    stewartj239 Member
    Syracuse, NY
    According to the official shop manual, capacity is 4.1 gallons and reserve is 1.1 gallons. I get anywhere from 46 to 48 MPG.
  5. mls03jbody
    Lafayette, Indiana
    I still need to take my fairing off so I can adjust the idle down. Its at 3k idle so it doesn't sit still very long.
  6. slowbird
    slowbird Member
    Toronto, Ontario.
    Okay...thanks to the few that have posted...and thanks Stewart for the shop manual info.
    I just finished my first Tankful on the Bike. I went to start the bike and while warming up it died...turned the Petcock to RES and the Bike started up fine.
    Went to the gas station and filled up. 11.4 Liters (approx 3.05 Gallons)
    I went about 160km (approx 100miles) on that first tankfull. If the info Stewart has provided is correct...then I had an extra 4 liters of fuel left.
    I did the math and my Fuekl economy comes up to:
    34MPG.
    14km/Litre
    So I guess I can probably go another 40kms or so on Reserve.
    I've been driving a bit better today...didn't leave it in too low a gear when cruising...only came close to redline once or twice.
    Anyway...that's my :blah: rant.
  7. stewartj239
    stewartj239 Member
    Syracuse, NY
    The mileage you guys are posting here seems terribly low. Even my 750 and 800 get in the low to mid 40s.
  8. eddievalleytrailer
    eddievalleytrailer Member
    Jonesborough, TN
    My '83 750 gets 36mpg around town, back and forth to work.
  9. slowbird
    slowbird Member
    Toronto, Ontario.
    Driving habbits are probably a big factor. A friend of mine has a VFR750 and he says it gets worse Mileage then his mazdaspeed Protege.
    Also...it's been pretty cold lately here...so I assume that with the warmer weather the mileage will get much better.
  10. slowbird
    slowbird Member
    Toronto, Ontario.
    Well...my Tire pressure was at 25psi :eek:
    I work at a car dealership and they decided to fill my tires with Nitrogen for free. Put them at 32psi. That should make things rougher on the road but my mileage should go up. :biggrin:
  11. chickenvoodoo
    chickenvoodoo New Member
    Houston Texas
    I am getting about 40 mpg driving to and from work everyday ( rain or shine ) LOL my car gets 14 mpg and the durango says it gets 10.8..... So the bike is the wise choice for me right now.....
  12. slowbird
    slowbird Member
    Toronto, Ontario.
    LOL...I know what you mean. I just finished another tank and I got 38MPG this time. all city. With some smarter driving...warmer weather and a lower idle I'm sure I can fair much better.
    In comparison my Daily Driver Grand Am GT gets 24MPG on a very good day with 90% highway.
  13. tbones86
    tbones86 New Member
    N/W Central Wisconsin
    I get 50 mpg w/ my 700 riding like a little old lady to church; worse is 35 mpg & that w/ extended speeds in the triple digits & corner carving. It has dropped some since going up 2 teeth on the back sprocket but not much.
  14. stewartj239
    stewartj239 Member
    Syracuse, NY
    That's more like it. I failed to mention that my commute is 95% highway speeds and almost no stop and go. That is why I can reach mid to upper 40s.
  15. chickenvoodoo
    Houston Texas
    I didn't mention before, but my commute is all stop and go...no hwy and I am 1 tooth up on the back....
  16. Colddevil
    Colddevil Member
    Wisconsin
    It depends. If I'm babying it I can get 45 or so.
    Recently, however, I've been getting a lot closer to 32-35.
    The only riding I've done thus far has been going out and taking some twisty roads running between 7-9k rpm for extended periods.
    When I start commuting this summer the numbers get a lot better.
  17. slowbird
    slowbird Member
    Toronto, Ontario.
    Yea...I've adjusted my idle to a more reasonable speed and my tires are inflated properly. I'll see how this next tank works out.
  18. JAMAC
    JAMAC New Member
    Brampton, ON
    VF500 Gas mileage
    hi, I've just bought an '84 VF500 and currently have 235km since I filled up first time...not on reserve yet.
    seems like I should be able to get close to 300km on a full tank (including using the reserve, but I'm not going to push my luck on reserve)
    cheers.
  19. JamieDaugherty
    JamieDaugherty New Member
    Fort Wayne, IN
    Yeah, I agree that the mileage stated is VERY low. The 500's should get 50mpg even when ridden hard. The 1000's get 40-45mpg! Anything under 50mpg on a 500 means that something is wrong.
    Also, 32psi is race track pressures. Try more like 40-42psi. In fact, it should say on the sidewall what the pressure should be. Sometimes they state this as a "max pressure" but in fact that's what you should run.
  20. pjrocco
    pjrocco New Member
    Aurora, IL
    I've gotten about 160 miles out of my last two tanks although I have been riding the 500 pretty hard. On average I get about 40 MPG...
