VF500 int. petcock help/question
Discussion in '1st & 2nd Generation 1983-1989' started by tom p, Jan 18, 2018.
  1. tom p
    tom p New Member
    central NJ
    one of the parts that where missing when I bought a 1986 int vf500 was the petcock. finally tracked one down. . and of course it being used and bought off ebay it leaks from the "riveted" face. what are my options if any? any way to work around the problem. a petcock w/o the vacuum and being left in the "on" position will flood the carbs.
  2. tom p
    tom p New Member
    central NJ
    the "search" is my friend, found the answer.
  3. Mind_Surfer
    Mind_Surfer New Member
    VA
    Tom on my '86 it attaches to the #1 intake.
    Sent from my XT1031 using Tapatalk
  4. tom p
    tom p New Member
    central NJ
    update : one of the parts that where missing when I bought a 1986 int vf500 was the petcock. finally tracked one down. . and of course it being used and bought off ebay it leaks from the "riveted" face. what are my options if any? any way to work around the problem. a petcock w/o the vacuum and being left in the "on" position will flood the carbs.
  5. squirrelman
  6. Mind_Surfer
    VA
    Tom, is the thin o-ring in place between the tank and petcock? Also what about the tank strainer? Bear with me, I'm going by memory, it has been a while since I had mine pulled out.
  7. tom p
    tom p New Member
    central NJ
    it leaks where the tip of the screwdriver is pointing, as you can see the "face plate " is riveted.[​IMG]
  8. tom p
    tom p New Member
    central NJ
  9. tom p
    tom p New Member
    central NJ
    theres a NOS for sale on EB for $500. ill buy a whole new bike before I pay $500. I see rebuild kits for the diaphragm part/end.
  10. tom p
    tom p New Member
    central NJ
  11. Mind_Surfer
    VA
    I agree, that's ridiculous.
  12. squirrelman
    Consider installing a fuel on/off valve and filter beyond the petcock.
    tom p and Mind_Surfer like this.
  13. motorhead1977
    motorhead1977 New Member
    Albany, NY
    That fuel tap looks a lot like the one on my 87 NC24 VFR400 R which is NLA and unobtanium in the real world. I happened to find one from a very nice seller in the UK but paid a price for it (Gladly I might add). Even with what I paid for mine the eBay one listed at $500 USD is way too much. Any chance you can drill out the rivets and install screws? I know working on it like that is not something I'd like to undertake without a spare but since it isn't usable in it's current condition anyway, whats to lose?
  14. tom p
    tom p New Member
    central NJ
    I'm on it, thanks
  15. forgriffindor
    forgriffindor New Member
  16. tom p
    tom p New Member
    central NJ
    thanks, I had tried to bypass the "vacuum" but seems the carbs got "flooded". unburnt gas was leaking into the cylinders and out the exhaust. which makes believe a float valve was stuck open ? ive cleaned the carbs and before install all float needles seemed good ???
  17. jeremyr62
    jeremyr62 New Member
    Ireland
    Limerick, Ireland
    Anytime you are filling carbs that have been completely drained, as they are filling, take a screwdriver handle (or chunk of wood, or...) and tap on the carbs a little. Floats can (and often) get stuck in the fully open position just because they are completely extended and get "cocked" ever so slightly. Just takes a light rap on the carbs to release. Seen it many, many times. Actually last night... bench testing some VF750F carbs that I rebuilt and one of the carbs started spewing before I could give it a love tap.
  19. forgriffindor
    Yeah the love tap method works. I just used it maybe 10 minutes ago.
  20. tom p
    tom p New Member
    central NJ
    thanks for everybodys help. I believe I have the petcock fixed. took buying two used units to make 1 good one. no leaks and when I "draw" on the vacuum line I get gas flow. hopefully ill get it on the track shortly
    Mind_Surfer and forgriffindor like this.
