Hi all, couple of things. trying to find the right brake discs for my bike is getting tricky. The bike is a 1985 (USA) vf700f. All 3 discs on the bike are the same 276mm 6 bolt pattern that look a lot like the TourMax 235743 disc. The rear shows a wear of 6mm legal limit and im at 6.5 currently so it neecd swapping. Trying to find somewhere that supplys the right disc is tricky - ive oredered and returned 2 incorrect ones so far - Any ideas? Also how should i tackle the carbs - the bike is in full strip down mode so wanted to fix/repair/refurb the carbs before reinstalling. Should i attempt this myself or is it better to send away - and if so, where best in the UK? Thanks
That bike uses the same size front rotors as the 91-94 CBR600F2. You could find some good used rotors and get a slightly updated look for a fraction of the price of new aftermarket rotors. https://www.ebay.co.uk/sch/i.html?_from=R40&_nkw=cbr600f2+front+rotor&_sacat=0&LH_ItemCondition=4 I did that on my VF1000F
