Hi after noticing a very loose timing chain on the Front Cylinders Cover i removed the cams and 4 bolts for the belt tensioner itself and the Unit should just lift out but the SLIPPER (long rubber thingy) is stuck down inside. Anyone ever have this problem? Ive wanked ganked pulled pryed but SHE IS NOT COMING OUT!!! IDEAS?
There's a loop on the end. You have to move it down and out of the it's holder then you can pull it out. #5 right?
Thanks for your quick reply and trying to help yep thats the one partner. I realize it just sits down in there freely since i just redid the rear cylinders. But this one between the front cylinders does not wanna come out!!! Any clue to why it may be stuck? And why my chain might be flopping around loosely? Also when i redid the rear cylinders and put the it all back togethor is it normal for the chain to be snug before i even release the tensioner out of service mode?
