VFR 1200 Fixed!!!!
Discussion in '7th Generation 2010-Present' started by alexdig, Oct 9, 2012.
  1. ytvfr
    ytvfr New Member
    Robcio, i'm not sure what the snow situation is like is Metcalfe, but have you put any significant KMS on your bike since the update has been applied?
  2. alexdig
    alexdig New Member
    St Catharines Ontario
    Details on my VFR fix.
    Dont know what to say fellas.
    Dan at Markham Outdoor Power in Ontario in conjunction with Honda Canada fixed my issue. I rode the bike today 25 kms to get my new tires put on.
    I have done over 1000 kms since the counter measure. They re flashed the ECU, changed the plugs...and adjusted the throttle.
    Dan took the time to work through and listen to the issue. I had already engaged the engineering department at Honda Canada and they worked together with Dan on a solution that has worked.
    I have no extra enhancements on my bike....stock manual.
    Dans number is 905-294-2355.
    Go see him!!!
  3. Robclo
    Robclo New Member
    ON
    Less then 200km since the update. It didn't take away the restriction. Mine has always run pretty smooth but I still gotta twiddle my thumbs until 5000rpm's or so in the first 2 gears
  4. ytvfr
    ytvfr New Member
    Alexdig, thanks for chiming in here.
    Robclo, thanks for the info. You mention that "Mine has always run pretty smooth"
    From what I understand the update is to fix the intermittent stumbling/stalling issue that a small amount of VFR1200 owners were experiencing (like alexdig, myself and mlloyd etc.) Trust me, you will know if your bike exhibits this behavior :)
    Based on Robclo's discussion with the service manager, It would appear a certain number of VFR's were running an older version of the ECM software.
    I cannot confirm or deny this as my bike has yet to have the re-flash performed, however I am scheduled to get it done for the end of April so I have to imagine I'm running the older software.
    The re-flash was never intended to fix the "hole" in the first two gears, as that is by design.
  5. Robclo
    Robclo New Member
    ON
    Well said.....
  6. alexdig
    alexdig New Member
    Issues
    Two completely different subjects.
    I have not yet completed the Rossi training...so twiddling my thumbs in first and second have never been experienced.
    I got my bike back...and it runs great.
    Love the bike.
  7. Robclo
    Robclo New Member
    ON
    :) I love it to
  8. crazybrother
    crazybrother New Member
    Fairfield CA.
    Are there any Canadian dealers on the Western side that are willing to help us Yanks out? I live in California and would be willing to ride up to Canada to get this done. Anyone know?
    Thanks.
  9. mlloyd
    mlloyd New Member
    So I had the VFR1200 out for a ride yesterday with my 12 year old on the back. We pulled up to light I pulled in the clutch to stop and the bike died. I re-started the bike went about 3/4 miles up the road was in 2nd gear going around a corner and the bike began to sputter then accelerated hard almost dumping my child off the back and onto the pavement. This bike is definately an accident waiting to happen. I called Honda and again will be bringing my bike into the dealership. I asked about bringing my bike to Canada for repairs and he advised me it would not be covered under warranty and that Canada has different emissions.
  10. ytvfr
    ytvfr New Member
    Hi all,
    I brought my bike in yesterday to get flashed. The dealership confirmed that my bike did indeed have an older version of the ECM software.
    I'm optimistic that this will solve the issue.
    I'm going on a 3000kms trip, leaving this Thursday, I figure that should be a good test.
    I'll update once I'm back.
  11. mlloyd
    mlloyd New Member
    Hope it works for you. Mine stalled three times in traffic in the last 4 days. Paperwork for lemon law has been filed.
  12. ytvfr
    ytvfr New Member
    Even though we have the same symptoms, your issue seems way more frequent.
    With that being said, I'm surprised that the dealer hasn't been able to reproduce the problem on your bike.
    Sorry to hear it's come to the lemon law stage.
  13. mlloyd
    mlloyd New Member
    Yea it seems more frequent than last year, the gear indicator on the display also flashes from a 3 to a - while cruising in 3rd and a 2 to a - if cruising in 2nd. Really odd goes back into the shop tomorrow.
  14. ytvfr
    ytvfr New Member
    Interesting. I can't say that I've had that symptom. Well I hope for the best, as I'm sure you are doing the same!
  15. lshark
    lshark New Member
    NY
    that's interesting because the gear indicator flashes "-" when the kill switch is in off position, it basically turns off the EFI.....hmmmm???
  16. RustyBit
    RustyBit New Member
    Melbourne
    Wow, that is different, haven't heard of that before. Once or twice I've had the "-" pop up while shifting but never on cruise. May simply be a dirty or faulty/loose connection or at worst an ECM. Good luck.
  17. mlloyd
    mlloyd New Member
    Dealership had gone through all electrical connections trying to diagnos stalling/stumbling. At least the dealership was able to replicate shift indicator issue during a test ride. I'll keep everyone posted, thanks for all of your input.
  18. ytvfr
    ytvfr New Member
    Got back from my trip the other day, and am sad to say that the problem still exists.
    I've informed Honda Canada and am waiting on the next steps.
  19. mlloyd
    mlloyd New Member
    I am truly sorry to hear this and can sympathize, mine is back in the shop for malfunctioning gear indicator and stalling stumbling since 5/1/13. Hoping that and my stalling/stumbling issue are related. They were able to reproduce the gear indicator problem however they have not been able to reproduce the stalling/stumbling. In the interim Honda Powersports of America has done nothing but continue to tell me to bring it back. My year warranty is now expired and I have filed my paperwork with the NYS Attorney General for Lemon Law arbitration. Please keep me posted and I will do the same. Anyone else experiencing these issues should step up and do the same.
  20. lshark
    lshark New Member
    NY
    how often does it happen ???
