VFR1200 Burning oil
Discussion in '7th Generation 2010-Present' started by MarkinReno, Dec 8, 2017.
  1. MarkinReno
    MarkinReno New Member
    Reno, NV
    Problem: she burns 1 quart / 500 miles
    Cause: Improperly installed PAIR O-ring.
    When: during reassembly after valve clearance inspection.
    Fix: replace all gaskets and O-rings when reassembling after valve inspection.
    MarkinReno [​IMG]
    Sent from my iPad using Tapatalk
    Ridem32 likes this.
  2. Ridem32
    Ridem32 New Member
    How many miles on your bike?
  3. MarkinReno
    Reno, NV
    27k miles. The burning started at 16k miles.
  4. Ridem32
    Ridem32 New Member
    So it started burning oil after you had valves adjusted and when put valve covers back on you had a o ring installed wrong? Then took back apart and installed new valve cover gaskets and o rings? Which o ring was it that was leaking?
  5. MarkinReno
    Reno, NV
    PAIR o-ring in the rear valve cover. It had been displaced in assembly.
  6. Ridem32
    Ridem32 New Member
    Pair valve?
  7. Ridem32
    Ridem32 New Member
    Glad you got it fixed fairly easy. Not a engine internal issue
  8. MarkinReno
    Reno, NV
    FYI vfr1200s don’t burn oil! No reports anywhere. This is a heads up.
  9. Ridem32
    Ridem32 New Member
    Good info. I love my VFR1200F. I bought a 2010 with only 600 Miles on it.
    MarkinReno likes this.
