  1. duccmann
    Thanks F3....the tape didn't leave a straight line..more jagged then anything. Sure peeled of easy enough.
    Now to get the film off it left behind. Worth a shot. ..oh well. After seeing that white one with the bags..thought the black on the lower part of the fairing looked awesome. $10
    No biggie
  2. Aimbot9000
    Aimbot9000 New Member
    Mount Holly,nc
    its best to pull the tape right after the last coat for a crisp line but no big deal if it bugs you you can just peel it off and redo. looks like a fun project.
  3. duccmann
    Thanks man....
  4. iamzombie
    iamzombie New Member
    CFB Shilo, MB
    Yup, plastidip is the most forgiving material to work with, if you mess up, you can start over easily.
  5. duccmann
    Well theres always a first time...couldn't believe how it just peeled right off.....the guy at Lowe's tells me the stuff is flying off the shelves. ..people at doin entire cars.....
  6. daver314
    daver314 New Member
    Vancouver, BC
    Check out dipyourcar.com, and also their YouTube channel. Guys are a little obsessed with the stuff. Btw, if you're masking dip, the running advice is to get all your coats on as quickly as you can, without it running, and then peel the tape off right away. No waiting for it to dry between coats.
  7. jerritt
    jerritt New Member
    Toronto
    Those lever's must be on there good because that's an awfully big hammer to use to remove the lever's
  8. jorgescar69
    jorgescar69 New Member
    La Puente, CA, United States
    I always make it a point to have it out and handy when i need to fix something.
  9. smooth1
    smooth1 New Member
  10. RobVG
    RobVG Member
    Seattle
    The 2.3m screws for my new trip meter knob came yesterday. Unfortunately they screwed up and listed their 4mm length as 6mm so they're too short. Installed it anyways, got a turn and a half on the screw and with a drop of blue loctite I think it'll hold. Sorry, no pics :playful:
    Took her out to rustle some leaves....
  11. Big_Jim59
    Big_Jim59 Member
    Dallas, TX
    I picked up the steering head bearings, the thermostat, two short hoses and the new left marker light I ordered. Such a small collection of parts. Such a huge pain in the butt to install them.
  12. f3racer
    f3racer New Member
    Thanks man! I bet that would sound awesome.
  13. duccmann
    Went outside and stared out my bike for 5 minutes
  14. jorgescar69
    Got a new set of fork seals in the mail today. I just need a decent day to install them. Atleast I have time to decide what weight oil to use. What was in the forks was mushy.
  15. f3racer
    f3racer New Member
    5w synthetic is usually best for your forks.
  16. jorgescar69
    F3, I would like to go a heavier weight the front and feels really mushy right now. I was gonna try 10 or 15
  17. Aimbot9000
    Mount Holly,nc
    ive been tinkering with mine all day in the cold trying to find out why the FI light keeps coming on. found a melted stator wire but a short ride post fix ruled that out as the problem. she died at a light with the FI light on but started right back up. sigh
  18. nookiaz
    nookiaz New Member
    Montreal
    Did pre-storage oil change (10w40 Motul v300 synth)...Rode around for a bit to see if there's any leak. None found. Might have over-filled by a bit...Read somewhere in this forum it's not serious unless it's waaaay overfilled.
  19. f3racer
    f3racer New Member
    Just remember the heavier the weight the slower it will travel through the fork internals therefore slowing the reaction time for your rebound and compression.
    If you can afford some new fork springs it work out better for you. Around $120 I think for a set. Doing the work yourself you could do new springs and valving for 250-300. I know that's not on everyone's budget but just a thought.
  20. Terry Smith
    New Zealand
    Sorry if this is teaching you to suck eggs, but have you gone through the diagnostic procedures to identify why the FI light comes on? The system should be able to point you to whatever is amiss based on the flashing code. I'd be happy to help you interpret what's happening.
