White Smoke on Start up!
Discussion in '8th Generation 2014-Present' started by Bubba Utah, Jan 4, 2018.
  1. Bubba Utah
    Bubba Utah Insider
    Utah
    I first of all may of been dupted by my dealer. Even after years of riding and only this being the first bike brandspanking new. He told me to ride it hard and up to redline within the first 500 miles to set the valves right. He said to alter it and fluxuate the rpms right of the bat. I questioned him, but this was the owner of the dealership and given that it was a more modern bike and a Honda I took his advice. Said and done. So now with 5,500 miles the bike smokes white for the first couple of minutes warming up, then goes to a vey faint white and mind you this Is winter at 40F. Is this normal or did I fu.. up the valves.
  2. Diving Pete
    Diving Pete Insider
    I'll make the assumption that you let the bike warm up first > before redlining it....
    In which case your dealer is correct, its a better way to seat the rings....
    However - you also need to change the oil more often during this period - I think there is a website that lists this break-in procedure, I'll see if I can find it..
    Bubba Utah likes this.
  3. Diving Pete
    Diving Pete Insider
  4. 34468 Randy
    34468 Randy Active Member
    With temps at that range, you could be seeing condensation. If you can see it, and it is oil, you would definitely smell it.
    Bubba Utah and Thumbs like this.
  5. GatorGreg
    GatorGreg Honda Fanboy/LitiGator
    Orlando
    Nothing to worry about - just a new Pope.
    J/K Bubba :D Hopefully it's just condensation as Randy suggests.
    squirrelman, andy kingdon and Lint like this.
  6. Thomas Gessner
    Thomas Gessner New Member
    Germany
    Munich, Germany
    At the risk of opening up one of those „how to break in a new engine“ threads: There has been a ton of discussions about hard break-in (the method described on the mototune site) and soft break-in.
    The consensus seems to be that for a race engine, hard break-in might be ok (it might free a few extra ponies), while for an engine that should have a longer life expectancy, soft break-in is advisable.
    I for one have concluded that Mama Honda knows best and breaking on according to what the manual says is the way to do it.
    I also think what your dealer says is irresponsible merde, excuse my french.
    White smoke shortly after start-up is normal, especially at low outside temperatures. If the engine continues to blow white smoke after it is warm, your head gasket might be blown (probably thanks to hard break-in).
    My 2c, of course.
    Gesendet von iPad mit Tapatalk
    Bubba Utah and andy kingdon like this.
  7. andy kingdon
    andy kingdon New Member
    Agree with Thomas above.... For my 4stroke dirt bikes (Honda CRF's) they are rode hard at mile one, but since this is my second VFR - I followed the HONDA break in procedure and I did not engage VTEC or even get of 5k of RPM for the first 500 miles or so.
  8. DriverDave
    DriverDave New Member
    Denver, CO
    You should be fine. I rode mine like I stole it from day one. Did the first oil change at 600 mi, then every 4k mi after that. Ran perfect, never smoked, never consumed oil or coolant, and had no problems for the 3 years/22k miles I owned it.
    Basically with modern engines, there's only 2 things that are truly bad for them during break-in...Immediate hard riding from a dead cold start with zero warm-up, and lots of constant steady RPMs on the highway. (like flying to a dealer in another state to get a good deal, and riding your brand new bike 500+ miles on the interstate back home)
    If you avoid those 2 things in the first 1k miles, either the soft or hard break-in technique will work fine.
    Bubba Utah and Thomas Gessner like this.
