Why buy an expensive rectifier?
Discussion in 'Mechanics Garage' started by bigoledave, Jan 15, 2018.
Tags:
  1. bigoledave
    bigoledave New Member
    My 1997 VFR is not charging. Looking at my Clymer manual, one obvious component that could
    cause this is a "bad" rectifier. I was going to go through a big series of tests..but then saw rectifiers
    on Ebay from $12.95 to way over $100. I just bought a $12.95 one and am skipping doing tests.
    What's to lose? Wondering why anyone would buy an expensive rectifier..what am I missing?
  2. fink
    fink Insider
    Cheap Chinese ones are known to fail big time.
    Buy a decent mosfet one
  3. thtanner
    thtanner Active Member
    Orange County, CA
    1) On average, a much shorter life-spam
    2) Consequence of #1 - getting stranded due to R/R failure
  4. OZ VFR
    OZ VFR Well-Known Member
    Old Toongabbie, Australia
    I tried a cheap Chinese one when I first got the bike.
    It lasted all of 4 hours and left me stranded 200km from home in the middle of nowhere.
  5. bigbadbass
    bigbadbass Member
    NEW YORK
    Japanese OEM supplier is Shindengen.
    Model # FH010BA is the OEM from ZX10...I've got on both my Ducati and VFR 7 seasons now, issue free.
  6. squirrelman
    squirrelman Well-Known Member
    i have it on good authority that the English translation of Shindengen is "You walkin' home, sucka !"
    TOE CUTTER and duccmann like this.
  7. bigbadbass
    bigbadbass Member
    NEW YORK
    to be clear, the FH010BA made by Shindengen is an older version dead reliable Mosfet....my boots none the worse for wear, thank ya'.
  8. bigoledave
    Ok..OK..that's all info I did not know...thanks to all the replies!! ( Now I may buy TWO cheapos...with one in my tank bag!) Seriously, I will l look in to getting another one of "MOSFET" design. Replies with specific
    recommendations welcomed! Thanks again -Dave
  9. duccmann
    duccmann Insider
  10. Diving Pete
    Diving Pete Insider
    The problem isn't that they fail - it's that they also take out other expensive components at the same time, as well as leave you stranded.
    Buy a good mofset one and forget about it.
    skimad4x4 and marriedman like this.
  11. marriedman
    marriedman Active Member
    Dayton, OH
    This is the most important bit of info I think. Melted connectors, toasted stators, and killed batteries can all happen with a crappy R/R. MOSFET is worth every penny.
    mello dude likes this.
  12. Laker
    Laker Member
    Ontario
    What Ducky said
  13. Gator
    Gator Insider
    The new version SH847 is 199.95 and the older but proven FHO20AA is 149.95. Both are his "super kit" and have home runs to the battery. Worth the extra coin for the new one? I don't know the difference, I think both need the adaptor plate too.
  14. duccmann
    duccmann Insider
    Bought the SH847 at 35K
    Didn’t want to be cheap in the wrong way plus my OEM stator is still going strong after 50K
    Knock on wood
  15. Gator
    Gator Insider
    What year is yours Duc?
  16. Lint
    Lint Well-Known Member
    Simi Valley, Ca.
  17. bigoledave
    Well...I learned all of this new info about cheap R/R too late...got my $12.95 one today and put it on.
    Works great TODAY. I only ride lately between my house and the marina...so..if it fails it is no big deal.
    I am concerned about the "taking out other stuff" but will chance it.
  18. marriedman
    Dayton, OH
    I'm on my phone, so I can't find the picture, but you should see the golden brown stator I got from a crap R/R.
    Sent from my phone. Please forgive brevity and spelling.
  19. bigoledave
    Ok..thanks for the input. Here is some info:
    ".....Common Types of Failure
    There are generally two ways for the regulator rectifier to fail. The first deals with diode burnout, resulting in battery drain. It is easy to assume that the issue is a bad battery because of symptoms such as dimming headlights, irregular meter readings and poor starts. Checking the voltage with a voltmeter versus relying on symptoms alone will prove highly beneficial. If the voltageought a coollittl;e drops below approximately 13 volts, the motorcycle will begin to drain the battery and eventually the engine will stop. Check for bad connections and corrosion; these also can cause voltage issues. The other failure type is shunt regulator burnout. Should the regulator rectifier fail to control voltage, the result will be battery overcharge. Again, a voltmeter will be useful for diagnosis. Generally, readings above 17 volts mean the regulator rectifier is not converting excess power. All of this excess voltage may cause the headlights to become extremely bright and then blow."
    So, I bought a cool looking small volt meter:
    2 of SODIAL(R) 5V-25V DC Voltmeter LED Digital Display Panel Mounted Round Waterproof Car Motorcycle Car
    Sold by: Best United
    $5.14
    ...and will mount it in my "dashboard" so I can always monitor bike voltage. I think by doing this,
    I will be able to detect any r/r failure issues waaay before any nasty damage effects can occur.
    -Dave
    Diving Pete and marriedman like this.
  20. Diving Pete
    Diving Pete Insider
    Thats a very good plan.
