00/01 guys, i need a easy dimension check please
Discussion in '5th Generation 1998-2001' started by abner malidy, Jul 6, 2013.
Tags:
  1. abner malidy
    abner malidy New Member
    mark it 8, dude
    my 5th gen is a 99 with the condom mirrors.
    looking for 00/01 mirrors without condoms if they fit the 98/99
    can you please confirm the dimension of the mirror mounting holes on your 00/01
    either center to center or whatever you can easily get calipers, tape, or a calibrated eyeball on.
    i would suspect that the dim was designed as an even easy metric value, not english
    emgo finally are listing a 00/01 viffer application again, but cant seem to provide the dimension. :rolleyes:
    thanks in advance !!!
  2. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    They should fit fine because I put the later model mirrors on mine to replace the condom mirrors. I went OEM because I heard some not-so-good thing about the quality of the EMGO's.
  3. OZ VFR
    OZ VFR Member
    Old Toongabbie, Australia
    Looks to be 50mm or 2".
    I believe they are a straight swap.
  4. mello dude
    The '00/'01 mirror are a straight bolt up, no problem to the '98/'99 5th gens. And for that matter a direct bolt on for 4th gens too.
    Its better without condoms. :cool:
  5. abner malidy
    mark it 8, dude
    thanks for confirming the 50mm dimension mate!
    im also considering some knock-off GSXR led units for adding some lights up top.
    everything i read suggests that the "triangle of light" adds HUGE visibility benefits.
