00 or 01 motor in a 1999 VFR?
Discussion in 'Mechanics Garage' started by dannll, Sep 12, 2012.
  1. dannll
    dannll New Member
    Springfield, OR
    Just blew up the motor in my 1999 VFR (19,000 miles). Wondering if a 2000 or 2001 motor would work if i use the 99 throttle bodies? Studying the manual shows only the following changes from the 99 (that i can find), wax unit for fast idle control, and 2 oxygen sensors in the 00/01. Also i would guess the ECM may be different or at least have an additional connection for the oxygen sensors. So if i take a 00/01 motor, use my 1999 throttle bodies, 99water pump (avoids the water hose connection for the wax unit), and of course my 99 ECM it should work. Am i missing anything here? seems to me that just keeping a 99 throttle body/water pump/ECM should allow me to use a 00/01 engine in my 99 VFR.
  2. tinkerinWstuff
    Pretty sure you have all the bases covered.
  3. reg71
    Sikeston, MO
    I have a 00 in my 98. I have had a few issues but it runs. Somehow I am lean but eventually maybe I'll figure it out.
  4. crustyrider
    crustyrider New Member
    North Country, New York
    that's because you ride the dog crap out of poor scratch....
  5. DaHose
    DaHose New Member
    Napa, CA.
    You should have no problem. Motor is the same for 98-2001.
    Jose
