02 VFR troubleshoot
Discussion in 'Mechanics Garage' started by lucasfrye54, Nov 22, 2011.
  1. lucasfrye54
    lucasfrye54 New Member
    I own a 02 VFR, 14000 miles, great shape. Just recently lost power while riding. Almost feels like a cylinder is out. It will run but just feels very sluggish. Bike is very slow of the start and engine note is off. New plugs have been installed and has not helped. Any ideas where to start?
  2. MrSleep
    MrSleep New Member
    Verdigris, Oklahoma
    Is the FI light on? If so then perform test procedure for what it is indicating. If not then Check battery, wiring, RR.
  3. squirrelman
    If you suspect a non-working cylinder, find which one and proceed from there.
  4. Kobe Diesel
    Kobe Diesel New Member
    CT
    check spark, individually
    check fuel pressure - maybe fuel filter is fouled
    check air intake filter
  5. TOE CUTTER
    If it is a dead hole one pipe is going to be much colder than the rest, easiest to check in my opinion.
