Hi All My 02 Vtec (non ABS) has an issue I need help with. The engine ticks over nicely, when I move the switch from off to 'park' the engine carries on. Then I switch it one further to full dim (no brights) and the engine cuts out totally. DEAD! She's now in pieces and it is breaking my heart. Especially there arn't many good weather days here in the U.K. All relevant responses will be appreciated, you can even reply to my email terrencelundin@hotmail.com Thanks
Sounds like a bad ground, either the ignition system is using the headlamps path to ground or vice versa & the ground can't handle both @ once. Can't help on where to look, your a decade+ ahead of my technology(86' model)
