$1000 2003 VFR
Discussion in '6th Generation 2002-2013' started by Captain 80s, May 22, 2020.
    2003 VFR, 30K miles.
    Bike was dropped and wouldn't start after previous owner tried to put it back together. Cranks over good with no weird sounds. Looks like the ignition switch and fuel cap have been replaced with aftermarket, which had me kinda nervous, and makes me think we didn't get the whole story. Scorpion slip-ons, PCIII, decent Avon tyres, Helibars, brakes and rotors excellent, replacement fairing kit that doesn't really look that bad. Decided we would roll the dice at $1000.
    I knew I should hear the pump prime when turned on and it didn't. After checking all the simple stuff (good battery, kill switch, side stand switch, fuel in tank, loose connectors) found the fuel cut relay and bypassed it, and we had power to the pump. Re-connected the plug to the pump and it lit up. Thought we had it! But, the fuel pump whines and doesn't stop. Just doesn't seem like it's actually pumping anything to build pressure. It is definitely under fuel. The kill switch will stop and start the pump and the FI light goes on and off accordingly. Oh, and we gave it a few good smacks with wood dowel too while it was "running".
    That sounds like a bad fuel pump, eh? Contemplating buying a cheap shitty pump just to verify and sort the rest of the bike before buying a good one.
  2. GreginDenver
    GreginDenver New Member
    Denver, Colorado
    What if the force of the "drop" caused the fuel pump assembly to come loose (partially) inside the fuel tank? What if the fuel pump is pumping perfectly (good PSI, good volume) but it has become disconnected from its fuel delivery hose? It's not hard to remove the fuel tank from the bike and investigate.
    Yeah, that is a good point. I was already going to pull the tank and pump assy to investigate eventually, but that gives me some hope.
    Thanks for posting!
  4. raYzerman
    raYzerman Member
    Millgrove, ON
    Not sure the stopping of the fuel pump is related to pressure, but rather a time-out ..... fuel cut relay. You could test you are getting fuel returned or fuel pressure... if so, leads you back to fuel cut relay?
    I don't think they time out. Pretty sure they pump until they reach a pressure limit, and then kick back on when needed. Could be wrong.
    Edit: I'm wrong. Stupid fucking spaceship.
    Took the tank off and removed the unit. Nothing seems obviously wrong unfortunately. The return line filter is weird, looks like a cast iron pan scrubby.
    I can put power to the unit and cover both spigots with a finger and doesn't seems to be doing anything except make noise. Gonna remove the pump from the assembly and try and test for any kind of flow.
    It seems weird that every other VFR pump problem is just getting power to the unit. Or they just don't work. But this bike did take a shot when it was dumped.
    Edit #2: I think the fuel pump is just fine.
  6. GreginDenver
    Denver, Colorado
    I know that the Maintenance Manual calls it a "filter" but it's just an anti-splash, anti-foaming measure to help the fuel to quickly and reliably pool around the fuel pump intake during low fuel situations.
    Your Edit #2, "the fuel pump is just fine", does this mean you "wet tested" the unit? Did you give it something (gasoline) to suck up and pump in a bench-testing situation?
    I will before moving on since it is out. That's why I said "I think". When the unit was still on the bike, I ran it with the gas cap open and a flashlight. The fuel was being slightly agitated but I couldn't for sure tell if it was vibration or flow.
  8. raYzerman
    raYzerman Member
    Millgrove, ON
    I gave a hurried reply the first time, I had to go to a job.... The ECU controls the time-out and activates the fuel cut relay, so electrically, that relay and connections should be checked. There is no pressure sensor with any feedback to the ECU for pressure. The pressure regulator will allow pressure to build and if the pump runs continuously, excess fuel will go back to the tank via the return hose. So..... you could check that there is flow via the return hose without having to tap into the pressure hose.
    But I think the issue is fuel cut relay/connection most likely.
    It now primes properly (2 seconds) and has spark. Turned out to be 2 things. An aftermarket ignition switch (brand new installed by PO) that wasn't routing power properly. It would make the main connection (red + red/black), but it wasn't supplying power to the other 2 wires (weird). After a combination of a couple jumper wires, still nothing. Fuck. Swapped out the FCR with the High Beam Relay (AGAIN!) and it primed for 2 seconds. Checked for spark... Yes!
    This is going to be a pretty fucking nice $1000 2003 VFR. I'll post some pics when I get it back together.
    Thank you for the responses and suggestions.
  10. raYzerman
    raYzerman Member
    Millgrove, ON
    Ignition switch threw you all off...... glad it's getting sorted out.
    Yeah it did. Last weekend while unplugging and cleaning every connector, I kept giving that ignition switch the stink eye. It always bugged me and I finally proved why. Having two issues can be challenging as well. But I'm glad it did, it was a score because of it.
    A few months back me and a buddy went and looked at a $500 1997 ST1100 ABS with a bunch of extras. He bought the wrong battery (opposite poles) and installed it without realizing. Ad said "I let the magic smoke out. It's not just a fuse." Within seconds of seeing the bike and crates of extra parts I walked away to start getting the tie down straps out.
    Got home, took off the side cover just to start looking at things. Opened up the Fusible Link cover... popped. Removed the EXTRA one out of the lid, installed it and she started right up.
    Here's the $2000+ fuse.
  12. GreginDenver
    Denver, Colorado
    Daaaaaaaaaaaaaamn!
  13. raYzerman
    raYzerman Member
    Millgrove, ON
    Had a similar experience..... the ST11's are still great.
    I love my ST. 1998. No ABS/Dual Combined BULLSHIT. Always wanted one.
    raYzerman likes this.
    Everything is operating now, but I have to wait for a air filter after cleaning out the nest that was in there.
    Need to get some new exhaust clamps, then I'll swap the mufflers so I can hide the small dent on the inside.
  16. NorcalBoy
    Nice! I would consider that a steal...even if you did have to swear at it a few times.
  17. squirrelman
    Amazing =!!! u scored big.
    New air filter arrived. Installed in the now clean air box, hooked fuel lines back up and added some non-ethanol. Pretty much fired instantly. Rolled it outside and ran it until the thermostat opened and the fan kicked on and off. Ran REALLY good. Mufflers actually sound really good too, not obnoxious at all. Couple small things to look at, the brake lights aren't working even after jumping the switch. And the fan is barely rubbing on something. I need to pull rad off a little and do some "adjusting" as the lower mount was a little wonky.
    I was also able to get the mufflers tucked more forward about 2 inches from that picture. I was going to swap the mufflers but I'll need all new clamps before I pull it completely apart and re-install.
    Oh, and charging system is good. Mid 13 at idle. High 13, low 14 at 5K.
    Still looking for a used left footpeg bracket.
  19. Captain 80s
    Rode it to a buddy's. Runs perfect, pulls pretty hard. PCIII seems to be fairly dialed in. Brakes feel good, so does suspension.
    Score.
  20. raYzerman
    raYzerman Member
    Millgrove, ON
    I know where to get fuses for less than $2000, but I'm keeping that a secret, LOL. Jeez, man!
