180 or 190 width rear tire?
Discussion in '8th Generation 2014-Present' started by Igrok, Apr 30, 2019.
  1. Igrok
    Igrok New Member
    Has anyone tried a 190 width rear tire over the stock 180 width? If so, what's your thoughts?
  2. XRedJar
    XRedJar New Member
    Edgewood, MD
    Typically, trying to fit a 190 on the stock rim sized for a 180 will pinch it and screw up the profile. Some have done it and like it, but not something I would do or recommend.
    Bubba Utah likes this.
  3. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    My thoughts? Why not stick with what works.
    The oversize tire may not fit the rim as well as the stock size, it may interfere with the
    swingarm, it may rub the rear hugger if fitted.
    And for what gain? Looks? Buy a Harley if you need a big phat tire.
    XRedJar likes this.
  4. Igrok
    Igrok New Member
    yeah, I don't need a fatter tire.
  5. fink
    fink Member
    OOTV, Gator and Thumbs like this.
  6. Gator
    Gator Insider
    vfr4.JPG Is it the best fit....? No probably not. Will you crash and burn? probably not. I have run 190's off my track bike that I have used on rain track days and they worked just fine.
  7. ducnut
    ducnut New Member
    180/60. Taller and ~20mm wider across the tread face, without much width increase at the sidewalls.
