1986 VFR750 fuel pump relay
Discussion in 'Mechanics Garage' started by walmark70, Mar 22, 2015.
  1. walmark70
    walmark70 New Member
    Does anyone know what fuel pump relay can be used in place of the original on a 1986 VFR750?
    You really don't need that relay ! :playful:
    That failed relay was the first problem i ever had with my '86, and i decided to eliminate it and install a bypass wire that sends power the pump whenever the key is on. ( Illustrated in FSM.) No worries about a relay crapping out while you're riding in tight freeway traffic, faster starting, less battery drain than using start button to fill carbs. And it's FREE ! :smug:
  3. NormK
    NormK New Member
    Squirrel, I know what you are saying , but my only concern is in the case of an accident and the ignition is not turned off, bike laying on its side, motor not running, pump will keep pumping, and fuel going everywhere. I'm thinking there must be a vacuum port somewhere up on the inlet manifold that a vacuum switch could be operated by, the type of plastic vacuum switches used in some of the LPG gas conversion kits, they are only about 40mm in diameter and work very well
  4. squirrelman
    I've gotta admit to dropping relayless bikes several times (engine running) without any fires.
  5. NormK
    NormK New Member
    We all get away with things a million time, it is just on that odd occasion when all the dots line up and you come unstuck.
  6. JohnnyM
    JohnnyM New Member
    Pullman, WA
    Forgive me, but what is FSM? I think I would like to do this mod on my 1986 as well.
  7. Samuel
    Samuel Member
    Los Angeles County
    Factory Service Manual?
  8. JohnnyM
    JohnnyM New Member
    Pullman, WA
    Well, now...that just makes sense. Can't have any of that...
  9. Samuel
    Samuel Member
    Los Angeles County
    lol (sadly) we have a saying at work, something to the effect of - if it makes sense, or is good for personnel or morale, or is practical and/or effective, etc, it ain't gonna happen...
