1987 Interceptor Grips
Discussion in 'Gear & Accessories' started by Austin H, May 20, 2019.
  1. Austin H
    Austin H New Member
    Hi all,
    First post here, I'm trying to replace the grips on my '87 vfr700. The right grip is standard size, but the left grip measures to 3-3/4". I'd rather not cut a brand new pair of grips, do they make grips in this length? Or is there a set of grips that're designed to cover the cut section with a bar end?
    Let me know, once again this is my first post, hopefully first of many!
    On the 86/87 VFRs the bar weight becomes part of the end of the handlebar. But you can find 120mm grips if you need shorter.
  3. Austin H
    Austin H New Member
    I don't have the factory bar weight, do you know where I could find bar ends like that?
  4. ridervfr
    Belgium
    Ebay? Use your air compressor with a blow stick to "blow" on new grips. Peace
