1999 vfr800 broken fork lock
Discussion in 'Mechanics Garage' started by kmurph38, Dec 6, 2018.
  1. kmurph38
    kmurph38 New Member
    Tucson, AZ
    In order to tow my VFR (don't ask why), the towing company forcibly somehow broke the steering lock. No one I contacted, including the towing company, has an explanation of how they did that. One mechanic suggested that, with great force on the handle bars or straps on the forks, the lock can be broken. It would be helpful to know how it was done that so that I can plan a repair - I don't have a clue what's broken. Any thoughts?
  2. Diving Pete
    Diving Pete Insider
    Two questions arise.
    1. Do you NEED a steering lock?
    2. Who's paying for it?
    I understand you might not think this is the most helpful, but, if you haven't figured out what they did to break it then you shouldn't really be fixing it... it's not that hard to replace it's just possibly expensive.... and do you really need it....
  3. Terry Smith
    New Zealand
    The steering lock is a pin (about 8mm diam IIRC) that projects out of the lock mechanism and engages with a socket in the steering head casting. I'd hope it is the lock pin that has broken not the frame! The lock mechanism is held to the upper triple by a couple of bolts with Torx heads that will be beasts to get out UNLESS you have a handy impact driver.
  4. kmurph38
    kmurph38 New Member
    Tucson, AZ
    Thanks. I've decided I'll skip the expense and time to repair. I can live without the fork lock. I've got the bike back, ridden it up and down a local, paved, twisty mountain road, and the front end seems OK. I've got other ways of securing the bike.
  5. bigbadbass
    bigbadbass New Member
    NEW YORK
    Uh, this condition justifies close inspection...I'd verify that the pin ( broken remnants?) or lock is not, under ANY circumstance, allowing *anything* to freely float, jam, move around. If so this could prove dangerous.
    You need eyeballs on it, eliminate any questionable conditions.
  6. Terry Smith
    New Zealand
    That sounds like some sage advice.
