1st Gen rack and bags
Discussion in 'Gear & Accessories' started by Grilldemon, Jul 1, 2010.
  1. Grilldemon
    Grilldemon New Member
    Penhold, Alberta, Canada
    I want luggage, but have to carry passenger. Givi makes a rack called the wingrack, but I didn't have time to get one. My bike is an 85 VF1000F
    So, I'm building my own.
    I bought some 3/4 Square tubing(steel, don't have the eqpt for alum welding and not very good at welding alum), so steel it is
    I boult this rack to accomodate a Rapid transit tailbag. Helicoiled the top of the hand holds and fabbed some tabs for the front mount.
    I installed new signal lights on the fender down by the license plate, stock ones were in the way.
    The bottom rails I ran along the rear supports (in grey primer) and bolted them on (metric hardware, of course). I used an existing hole for the rear bolt, and heli-coiled it for an 8 mm bolt. the front bolt has a nut , but the support is channelled, so I ordered sone DEvcon plastic steel (part # 10240) and will fill the channel and heli-coil it for an 8mm bolt also. Devcon is awesome stuff, every diy'er should have it in his/her shop.
    I added a cross brace just under the tail light.
    Here is a pic of the bags mocked up. I still have to finalize the hold down straps. Saddle bags are Rapid Transit also
    Everything is tacked together right now. I have to add another brace , remove it and weld it all up, and do some grinding.
    I will then paint it to match my fork brace:
    Will post pics when completed
  2. Grilldemon
    Here is the rack all painted up
  3. crustyrider
    crustyrider New Member
    North Country, New York
    Nicely done griddle.. Looks like it will work out nicely
  4. RoundtheNextBend
    RoundtheNextBend New Member
    Thanks guys-
    Nice work on that rack Griddle. If I could Id build one for myself.
    Dwntwnsac, for the cortech bags, do they just strap accross the seat, or do you need a rack of some sort to keep them away from the wheel?
