2000 VFR Part Out
Discussion in '5th Generation 1998-2001' started by NightViper19, Sep 2, 2010.
  1. NightViper19
    NightViper19 New Member
    Ohio
    I turned a 2000 VFR 800 into a Reverse Trike. I was making a thread instead of an ad cause I was gonna update as I manage my inventory.
    UPDATE: If forum rules allow, everything is OBO. I will research prices and see what a good price would be for both of us. Im not looking to flip these parts for tons of cash, just looking for some funds to get this next project rolling.
    See posts for satisfied customers.
    Tags in photobucket are actually the description.
    PICS HERE
    Also more pics in the Facebook page under photos.
    So far, heres what I got for sale: (everything in good condition unless otherwise noted)
    Side Fairings - but they are rough. Definately fixable, but rough. Pics added in album.
    Big Box of Connectors - Got a cut up wire harness from both a 5th and 6th gen. Would happily cut off connectors for whatever you need, just gotta explain what connector or show me a picture.
    Rear Sprocket
    Rear Rotor
    Shock and linkage
    Triple clamps - with bearings (Pics on facebook - Parts)
    Right clip on handle bar (repaired, welded)
    Rear brake caliper, and master cylinder
    Front brake calipers, and master cylinder
    The PAIR system (EGR-type thing)
    Flapper valve actuator and vacuum system.
    Rear subframe (Sold)
    Left clip on handle bar (Sold)
    Radiators, with fan (Sold)
    Single Sided Swing Arm (Sold)
    Front forks (Sold)
    Tool Kit (Sold)
    Rear plastic tail cowl (Sold)
    Front Rotors (Sold)
    Mirrors (Sold)
    Front Turn Signals (Sold)
    Pegs and brackets (Sold)
    Corbin Seat (Sold)
    Solo Seat Cowl (Sold)
    Tank (Sold)
    Front and Rear Rim (Sold)
    Tail light (Sold)
    Passenger grab rails (Sold)
    PLEASE NOTE: Items in the SOLD category are legit SOLD.
    Thats what I got for now. If you want to see pics of the trike (and progress), go here:
    Reverse Trike | Facebook
  2. leftcoast
    leftcoast New Member
    somewhere near Seattle, but my heart is just north
    wow....now this is a PROJECT!
    howmuch for the front rim?
    front forks?
    bob
  3. drewl
    drewl Insider
    Virginia Beach, Va
    Crazy, baby.
  4. NightViper19
    Ohio
    Man, I havent really thought about prices. I dont have a front end stand, so I cant sell the the forks and tire until I get it bolted to the frame.
    If you are interested in an item, let me know and I'll take up close pics of that thing. If I dont get much interest here, I'll put everything in the Classifieds or Craigslist when I get farther into the project. This is going to be a winter project for sure.
  5. btay67
    btay67 New Member
    Peculiar, Mo
    The reverse trike pics look awsome. I look forward to seeing this come together. After you part out the bike a while I think you need to change the thread header to reflect your new project. I would hate for others to miss out because they thought this was a "parting out" thread only. Just my 2cents. (probably worth less than that though).
  6. NightViper19
    Ohio
    Thats why I made the Facebook thread, so that people that werent a part of the VFR forums could still follow my build. I'll make one here later on when I get the frame built.
  7. teirich
    teirich New Member
    Would you be getting rid of the cowl bolts or are you going to be needing them for use with your project?
  8. NightViper19
    Ohio
    Do you mean the two bolts that hold the rear seat cover on? If you are talking about those, then ones I have are just regular Philips heads with spacers, which Im guessing is not stock.
    Im relocating all the electronics, and making my own fiberglass body, so there wont be a need for anything over the rear tire, except for the frame and body and such. Trying to keep a little front heavy weight distribution to help with handling and understeer more than oversteer. If I want oversteer, just hitting the throttle in a corner should slide the back end out and thens I got plenty of oversteer :)
    I've read quite a bit on Reverse Trikes, and Im mainly following other engineers work while adding in my own taste
  9. Squamish VFR
    Squamish VFR New Member
    Squamish BC Canada
    :pop2: Will be watching this one for sure...
  10. teirich
    teirich New Member
    Those are the bolts that I am talking about. I had to take them out to get to the r/r because I need to replace it and the bolts for the r/r along with those from the cowl were misplace by someone who didnt think they were anything important. So now I am in a bit of a bind looking for them and not wanting to pay a ton to order them from the part magazines.
  11. NightViper19
    Ohio
    I have one stock one, so I can match thread and length, and mill a spacer if you want. I'll send you a picture of what I got when I get a chance. PM me your email.
    EDIT: The cheapest I could find them new is at powersportspro.com for 12 bucks a piece, but that kinda is "pay a ton" cause 24 bucks for 2 bolts is alot. I dont have the 8mm washers, but those should be easy enough to find at a hardware store. I wont need the ones I have, so shoot me an email and I'll get you a pic. You pay for shipping and they are yours.
  12. NightViper19
    Ohio
    First post updated. Pics now available.
    Woah, unless the ebay machine is playing with me, it looks like the front forks (in good condition) are worth like 400? and like 300 for the front trim? This bike must be rarer than I thought. Does that sound right?
    I even got a single sided swing arm for sale in the classifieds, but if no one wants it, I'll just make one of my other bikes single sided :D
  13. NightViper19
    Ohio
    Also got the side fairings, but they are rough. Definately fixable, but rough. I was gonna melt down ABS plastic shavings in Acetone and make them like new, but now its not gonna be a VFR anymore, so no point. Pics added in first post album.
  14. Davis5g
    Davis5g New Member
    Pittsburgh, PA
    Is the bike red? If so, i would be interested in the front fender if its in good condition.
  15. NightViper19
    Ohio
    The bike is yellow, as the pictures show.
  16. Davis5g
    Davis5g New Member
    Pittsburgh, PA
    Ooops... didn't see the pics tab. I feel real smart now, thanks though.
  17. Jakobi
    Jakobi New Member
    Klamath Falls, OR
    Front brake rotors?
    -Jake
  18. NightViper19
    Ohio
    Im trying to keep as much together as I can. I got a guy wanting the whole front of it, but if he backs out, then I'll part it out.
  19. Big3
    Big3 New Member
    Lancaster, Ohio
    I still want the chain guard :)
    you get it from the shop yet?
  20. NightViper19
    Ohio
    Yes, I did. Its sitting in my garage, ready for some use.
