2002 vtec forks
Discussion in '6th Generation 2002-2013' started by Marcegie, Jun 29, 2016.
  1. Marcegie
    Marcegie New Member
    I'm looking to change the forks on my 2002 vtec bike , could someone advise if I am able to use the older models forks or any other type I can use as I'm struggling to source 2002 ones
    Marc
  2. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
  3. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    Are you looking to upgrade or just replace damage forks.
  4. Lint
    Lint Member
    Simi Valley, Ca.
    Are your forks bent or have some other defect, or do you simply want to upgrade?
  5. RVFR
    Yea Jamie is the one to go too for sure, on the short and easy side he has a lot of knowledge with our beloved VFRs
  6. Marcegie
    Marcegie New Member
    Replaced fork seals and noticed a bit of pitting , it's only the left side that's leaking
  7. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    Time for a brake delink and f4i forks :)
  8. RVFR
    ^ what he said.
  9. Marcegie
    Marcegie New Member
    Thanks for info what s involved in a brake delink ?
  10. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    A free weekend, some skill, patience and some creativity with the brake lines. The worst part was dropping the rear sub frame to remove the proportioning valve. The second worse part was figuring out the brake lines. You can keep one of the rear brake lines and use the other to make the caliper loop
    Sent from my Nexus 6 using Tapatalk
  11. RVFR
    Just so happens I'm just about to do this very thing, de link that is. I'm just in the think tank on how I want to do those brake lines and in that is what version too. other wise it's like what Candy said, One might grab a beer with some patience after you get the parts and go to it.
  12. Marcegie
    Marcegie New Member
    Thanks again sounds a tough job
  13. Marcegie
    Marcegie New Member
    Good luck I'll be looking to put it in a garage not too handy still learning
  14. Marcegie
    Marcegie New Member
    Cheers guys
  15. RVFR
    awe. man ain't that bad. ;)
  16. Marcegie
    Marcegie New Member
    Would it make a big difference to the handling ?the forks what year of f4i a 2002?
  17. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    The f4i forks are fully adjustable (preload/rebound/compression) vs preloaded only VFR forks.
    4 piston fixed calipers vs 3 piston sliding calipers.
    Less unsprung weight, from losing the secondary master cylinder.
    Less sprung weight from losing the proportioning valve and 100 feet of brake lines.
    Million times easier maintenance. Bleeding and changing the fluid in linked brakes sucks.
    Less risk of dragging brakes. This is starting to happen on more and more bikes equipped with linked brakes, due to secondary master cylinders and proportioning valves gumming up with age.
    I believe Honda recalled the Goldwing due to it's linked rear brake dragging, overheating and setting on fire.
    But yes, with minimal work (proper spring rate springs, new proper weight fluid and the right adjustments), these forks are terrific for the VFR. The brakes are great too and I believe that they can be be upgraded further to 954/rc51 calipers with minimal effort.
  18. Marcegie
    Marcegie New Member
    You certainly make this sound worthwhile Candy
    Thanks Again for the advice I'll start looking around for the f4i forks
  19. RVFR
    It could depending on what your intentions are and what you're looking for, they are more adjustable, that in it's self IMO makes them better
  20. FightingChance
    FightingChance New Member
    Marina del Rey, CA
    I'm in the same boat, my forks look like they've been underwater for a few months and while my brakes work 'ok' now, I want better brakes and also a handlebar instead of clipons.
    I'm down for a 'front end party' here in Socal if and when someone wants to take this kind of task on. I can bring tools, be a set of helping hands, etc. I turn a decent wrench and would appreciate reciprocation when it comes time to do my own bike.
