2007 VFR800 power drops off after 9K RPM
Discussion in '6th Generation 2002-2013' started by cwattsr77, May 24, 2022.
  1. cwattsr77
    cwattsr77 New Member
    Hi all,
    I have a 2007 VFR800. I have had for about 9 months and not really had chance to ride it much. What riding I did was mostly local with no WOT moments. Over the past few weeks I had more time to take her out and open her up. Every time I get to around 9000 rpm the power falls off. It does not matter what gear. The feeling is almost similar to hesitation from lack of fuel or maybe spark plug breaking down. It will go over 9000 rpm but hesitates in doing so. The bike has 7700 miles and the last owner tried to remove the baffles out of the stock exhaust and failed. He replaced with a Delkavic which does look and sound nice. Is there a possibility the bike needs a PCV as the stock fuel mapping may be a problem with this exhaust. I plan to replace the fuel filter and fuel pump.
    Looking for some suggestions.
    look for FI codes
  3. cwattsr77
    Can you please expand. I do not have the FI light on. How do I find codes?
  4. squirrelman
    it's in the manual, read it.
  5. Terry Smith
    Maybe the airbox is full of critter bedding or food.
  6. Grum
    Grum New Member
    Even though its only done 7,700 miles, if it was mine, I wouldn't hesitate in fitting a new set of plugs - NGK IMR9B-9H's. With the fault you have, plugs need to be eliminated.
    - Never had any issues with the Delkevic exhaust on my 2009 6gen.
    - If your Fi Light is NOT on, then you have NO Active Faults as seen by the ECM. If your Fi light was on you need to have the Ignition On and Sidestand down before it will flash the trouble code.
  7. skimad4x4
    France
    French Alps & London
  8. cwattsr77
    Airbox is clean. I will look into changing the plugs as recommended. I watched the FI Video and will check out the bike on the weekend and see what I come up with. Thank you 'Grum' and 'Skimad4x4' for the constructive diagnostic advice. Will follow up.
  9. VFRJohnL6
    VFRJohnL6 New Member
    i' ve got the same issue on my 03 bike as well.
    it gets to around 9.5k in third onwards and struggles to get past the 10k mark,it takes a while but it will get past past.
    i've fitted new plugs, new FPR, cleaned the injectors, tried a different tank & fuel pump,replaced all the vacuum pipes on the throttle bodies, balanced them as well.there are no FI lights or faults on the dash.
    it's a mystery to me.
    i've ordered another crankshaft sensor as it mabye that.
  10. Grum
    Grum New Member
    Wonder if its struggling for air? Have you tried a new air filter, you don't mention anything regards the state of the air filter?
    Would seem unlikely, though not impossible I guess that a crank sensor might play up at higher RPM's, it is purely the RPM sensor, normally incredibly reliable, and if it was playing up I would imagine the bike would really let you know and the Tacho would badly fluctuate as well. Also, if the ECM detected a faulty crank sensor it would throw up a Code 19 and shutdown the engine!
    Even if it was intermittent you'd have sudden complete power loss, then a burst of power if it rapidly came good again, something you would absolutely notice.
    Might also be worth running the TPS voltage checks from idle to WOT.
    Good Luck, hope you eventually find an answer, and Please post your findings.
    VFRJohnL6 likes this.
  11. VFRJohnL6
    cheers for the heads up Grum. i did think if i had sensor issues then the FI light would be on or coming up when the issues arose.it's got a brand new K&N filter in the air box.
    i've took off the PAIRS system, removed the O2 sensors and had the correct blanking plugs fitted, but this flat spot problem was there before i did all that.
    i've removed one coil stick at a time with a newer one and also done the same with a spark plugs, no difference.
    the crankshaft sensor arrived today and it isn't that, it's the ignition coil pick up up sensor, am pretty sure it's not that as i would be getting FI light showing.
    i'm looking to get it on a rolling road dyno tester and see if that will show up what the problem is.
    i go to the french alps at the end of this month, so it can stay as it is, at the end of the day, i'm doing 120mph in 4'th gear at 10K, so can live with it for now as i will have full luggage and a pillion on , so won;'t be going to mad out there ;-)
  12. squirrelman
    ^^^^ hook up with skimad, he'll get you sorted ! :cool:
  13. cwattsr77
    So I changed the fuel pump, fuel filter and cleaned the air filter and checked the plugs and no change. No FI codes. Waiting on delivery of spark plugs but I highly doubt that's the problem. Not sure if VFRJohnL6 has any updates. Please share if you do. I have just received a new PCV today and will install soon and see if that changes anything. Also looking for a PCV map besides the Dynojet defaults. Was looking for the one from HeroRR on Youtube to no avail.
  14. VFRJohnL6
    nothing from me am afraid mate.
    just done a 1575 mile trip around scotland and bar the issue i have with it, the bike was faultless.
    two up with the panniers and small top box was getting around 38mpg and i was riding hard and fast all the time, quite a few adventure bikes despatched in quick time ;-)
  15. cwattsr77
    Sounds like fun. Being an ex-pat I miss them rides...weather permitting mind you. Will update on my finding when the weather here cools down.
  16. mofo
    mofo New Member
    Orange County Ca.
    I’m just commenting to follow this thread. I’m having issues with my bike 04 A with 86K miles cutting out at highway speeds, sometimes dying completely, some other times cutting out momentarily before lurching like when you bump start it and can’t find the solution. I get no codes, but may be I should try to clear any codes and see what happens.
    As a side note, I changed air filter, spark plugs, all the hoses, flushed the coolant, rebuilt the clutch master, installed new clutch hose, clutch friction plates and more, I’m sure I disconnected some sensors relays and other things I shouldn’t have in the process of doing all that. I may add that my bike cutting out started before I did all that and has gone from an intermittent issue and has escalated.
  17. Grum
    Grum New Member
    Have a close look at Main Fuse B 30amp located next to your Starter Relay. This is the fuse that powers all your EFI stuff. The fuse, its holder and wiring can suffer badly from overheated, burnt, high resistance connections.
  18. mofo
    mofo New Member
    Orange County Ca.
    Will do Grum. I’ll do anything anyone suggests. I’m sick of this issue already but want to do as much as I can before calling a mechanic.
    I have the manual, but if you tell me the location of the fuse and relay I’ll appreciate it. I’ll dedicate a couple of days to the bike soon.
  19. mofo
    mofo New Member
    Orange County Ca.
    Never mind, I found it. Thank you.
  20. Grum
    Grum New Member
    Also couple of questions that may help diagnose your problem.
    1. At the time the bike fails does the FI light come on, even momentarily?
    2. When the bike dies. Do your hear the Fuel Pump prime with evey cycling of the Ignition Switch?
    3. When the bike dies can you attempt an in gear start, clutch in side stand UP? This might point to a faulty/intermittent side stand switch?
    4. Is there ever a situation when pressing the Starter Switch it doesn't crank over?
    Another weak link in your EFI power source in the Blue 18p connector where power goes through this up to the Engine Stop Relay then back through the connector off to all EFI. Poor high resistance contacts can be at this connector. Refer your bikes wiring diagram.
    Just a few more things worth thinking about, good luck.
