2nd gen 700/750 valve adjustment question
Discussion in '1st & 2nd Generation 1983-1989' started by Dukiedook, Feb 10, 2012.
  1. Dukiedook
    Dukiedook New Member
    Kansas City, USA
    Ok, just wanted to make sure I did not futz up the valve adjustments on my bikes so I'll ask the question after looking at 1st gen valve adjustment procedures.
    The 2nd gen design changes allows you to check each valve one at a time and adjust without having to use two feeler gauges at the same time on the valve pairs like on the 1st gen valve designs, correct?
  2. TOE CUTTER
    You are correct sir.
  3. captb
    captb New Member
    Yes and I just checked mine all exactly the same as when I did them 12K miles ago. :smile:
  4. crustyrider
    crustyrider New Member
    North Country, New York
    or you take it to TOE CUTTER and he adjusts the valves for you.. boom!!!! end of story valves are done and all it cost you is some beer a little bit of harassment and dealing with some crzy ass dogs
  5. Dukiedook
    Kansas City, USA
    That would be a serious ride for a valve job Crusty.
