49 state bikes.....
Discussion in '3rd & 4th Generation 1990-1997' started by goinphaster, Jan 3, 2007.
  1. goinphaster
    goinphaster New Member
    California
    need to know if 49 state vfr's, specifically 1994, have the PAIR system installed from the factory..... and if the crankcase breather hose is routed into the air box or if it has it's own filter. a bazilllion thanks in advance.
  2. RVFR
    Dang had it apart, didn't see nothing in the way of a crankcase filter.. maybe this will help?
  3. goinphaster
    California
    thanks RVFR, good pic! the crank case breather hose is routed directly into the air box as seen in this pic. do you know if your bike has Pair installed on it? these would be tubes going into the area around the header ports....
  4. RVFR
    Nope, no such animals
  5. douglasthecook
    douglasthecook New Member
    Tucson, AZ
    I'm not sure if my bike is a Cali model, or a rest of the USA model, but I removed the pair system. Did some research on it, and decided that I would remove it completely. I can post pics if needed when I get home tonight.
  6. goinphaster
    California
    I just need to know if non CA models have PAIR or not, from the Factory. It revolvs around a Non-U.S. bike I am trying to register- legally. if 49 state bikes don't have pair it makes it that much easier to modify the bike to meet U.S. standards...
