4th gen brake mods advice
Discussion in 'Mechanics Garage' started by Bikermike, Jun 10, 2007.
  1. Bikermike
    Bikermike New Member
    I am exploring options to upgrade the brakes on my 1996 VFR.
    Does any one have any suggestions??
    Thanks,
    Bikermike
  2. douglasthecook
    douglasthecook New Member
    Tucson, AZ
    I'm fairly certain that VTR forks are a drop-in replacement. you can also swap out the complete front end to either RC-51 or CBR 929/954 forks. That is not just a fork tube swap like the VTR is, for the CBR swap you also have to change out the triple trees, as well as make a few other changes. All in all, it's fairly easy to do.
  3. mello dude
    Romania
    The VTR forks or lowers would definatly be an upgrade if you would want to spend the bucks. - I had a 4th gen - I think first save your bucks and try some better brake pads. If that isnt good enuff - you can use up the pads to decide, then consider if you want to delve into the more major mods. The plus is that the parts go together fairly simple - Honda stuff is pretty interchangable for the same fork tube size. (41mm)
    MD
