4th Gen Overcharging issue???
Discussion in 'Mechanics Garage' started by faran, Jun 8, 2019.
  1. faran
    faran New Member
    Have recently acquired a 4th Gen VFR and it has VFRness installed on it. Along with a bigger and heavier R/R with fins.
    Very initial charging voltage after starting it at low and high rpms is between 17-18V and then drop down to 14-15V, I took it out for a ride today and was able to see battery was being cooked and was bulging up, along with an acid smell :(
    Could anyone please look at below pictures to see if connections are good and in right order? Thanks for the help and advice :)
    https://postimg.cc/TpjMhVZ9
    https://postimg.cc/3d06DgV6
    https://postimg.cc/xq3GpqHC
  2. mello dude
    Romania
    Park the bike immediately. Your R/R is toast. Chances are it took out the battery too.
    You need to update with a current tech R/R --- either the FH020aa or the SH847aa - the later is a tough mount up.
    Do a direct wire up to the battery as per current art. The VFRness wont be needed.
  3. faran
    faran New Member
    It has the aftermarket R/R and bigger fins, not really sure if any connection is being messed up and causing higher voltage?
    Or it surely could be the R/R?
  4. mello dude
    Romania
    Overvoltage is definately an R/R issue.....bad luck, but will need to be replaced..
    Whats the mileage on your bike?
  5. faran
    faran New Member
    Yeah battery is toast, so as R/R.
    Thanks for the help MD.
