Hi all, just wondering if anyone has come across this problem before - the tacho on my 1997 4th gen has ever so slowly lost its way. It started working intermittently and got progressively worse to the point it has stoppped altogether. A few days after the tacho stopped, theturn signal indicators on the dash started flashing opposite to what I pressed - press to turn right and the left indicator light on the dash comes on, not the right side one. Its doing the opposite to what I push on the bar switch. Could this be a dodgy connection in the dash around hte tacho, maybe water getting into the connectors and causing corrosion ??
