5Gen Clutch Master Rebuild Kit
Discussion in '5th Generation 1998-2001' started by mhzpower, Sep 7, 2016.
  1. mhzpower
    mhzpower New Member
    Brunei Darussalam
    Vancouver, BC
    Hi Guys,
    I ordered a rebuild kit for my 2001 VFR and I found that it was too big. Apparently the parts catalogs point to the 98-99 version.
    I know mine is a 1/2" (12.65mm) version.
    Does any one have a confirmed part number for the rebuild kit?
    I've looked up:
    22886-MB0-305 (apparently a 4th gen version)
    22886-MAT-E01 (shown for the '01 on fiche)
  2. OOTV
    OOTV Member
    I'd have to check my order but I bought a kit from Partzilla earlier this year for my 01. Let me see if I can find the order and get the part number.
  3. Terry Smith
    According to Partzilla, 22886-MB0-305 fits 98 and 99 VFR800 but also 01 VFR800 (and I suspect that is an error).
    22886-MAT-E01 fits 00 and 01 and the 6th gen.
    According to the service manual, the 98/99 has a 14mm clutch master, and the 6th gen has 12.7mm, so if you have that diameter master, get the MAT part.
    Interesting that the slave pistons for the 98/99 and the 6th gen are the same, so presumably the change was made just to lighten the clutch pull.
  4. mhzpower
    mhzpower New Member
    Brunei Darussalam
    Vancouver, BC
    Thanks. I tried using the MAT part number with a local dealer and they gave me the wrong one.
    Sent from my SM-G903W using Tapatalk
  5. OOTV
    OOTV Member
    Oops, my bad, after looking for the receipts I found that it was my Duc's MC that I rebuilt and the clutch slave of my 01. Sorry about that. Looks like Cadbury got you what you needed though, right?
  6. mhzpower
    mhzpower New Member
    Brunei Darussalam
    Vancouver, BC
    Well sort of. I will just have to bring my callipers to confirm the OD.
