5th gen coolant drain bolts mixed-up - which goes to cylinder drain and which to coolant pump cover?
Discussion in 'Mechanics Garage' started by motogp, Feb 17, 2023.
  1. motogp
    motogp New Member
    Sacramento, CA, USA
    Ugh - changing coolant on my 2001 VFR and I mixed up the two bolts that drain:
    • the cylinders
    • the water pump housing (main drain)
    Same size, same copper crush-washer, but one is about 2mm longer (an un-threaded tip)
    I'm thinking the longer is the cylinder drain...
    Thanks 20230217_112554.jpg 20230217_112638.jpg 20230217_112554.jpg 20230217_112638.jpg 20230217_112554.jpg 20230217_112638.jpg
    shorter one goes into waterpump, i'm 90% sure.
  3. motogp
    motogp New Member
    Sacramento, CA, USA
    Yep, that's what I figured (thanks for your input). And...the stamp on the head of the two bolts was different: the short one had the same "C" with a . (dot) in the middle as another bolt on the pump housing; the other had some sort of hieroglyphics. And, I speculated that the extra un-threaded tip on the other was to be used as a "finder probe" given that its location (on the underside of the Left Front cylinder, going straight up, and with limited sight-lines) was to be used to poke around to find its home without buggering the threads.
    Anyway, that's where I put them and all seems well after running it up to temp in testing.
  4. NorcalBoy
    They are actually supposed to be the same length - 12mm. I would replace the one with the completely knackered threads, at a minimum, and get new sealing washers.
