5th Gen owners: Need some torque specs for shock install
Discussion in 'General VFR Discussions' started by Puma Cat, Feb 2, 2008.
  1. Puma Cat
    Puma Cat New Member
    East Bay, CA
    Reg, EddieValleyTrailer, or anyone else who has done a shock swap on a 5th gen, need some info pronto...
    I haven't gotten my '99 VFR service manual yet, but I wanted to install my new shock in the bike today.
    Please refer to Reg71's shock install Wiki for photos for the bolts I am talking about here:
    http://wiki.vfrworld.com/index.php/Installing_Penske_Shock_on_98_VFR).
    Does anyone know the torque specification for:
    1) The bolt that is under the tank/rubber flap that holds the top of the shock/clevis to the frame
    2) the bolts for the shock link plate. This is the triangular linkage at the bottom of the shock. There are three bolts here, but I am assuming the torque on all of them is the same spec.
    3) The bolt that goes through the top of the shock that attaches to the clevis
    (the u-bolt thingy Reg71 refers to in his shock install Wiki article). Reg shows a picture swapping the clevis over to the Penske. Need to know the torque for this.
    If any of you have a shop service manual and can look up these torque specs for me, it would be a big, big help.
    Many thanks in advance!
    -PC
  2. Joey_Dude
    Joey_Dude Member
    North Georgia
    At VFRD (Gasp! I know I said the V Word!) you can get a free scanned version of the shop manual. Just register with them and go to the Downloads section.
  3. Puma Cat
    Puma Cat New Member
    East Bay, CA
    Thanks, Joey, I will check it out. I guess I will have to join the Dark Side...(i.e, VFRD(ark).
  4. mello dude
    1) Upper bracket nut torque - 31ft-lbs
    -- Upper shock clevis nut - goes crosswise into the u bracket - 31 ft-lbs
    -- Shock link nut -frame side - 43 ft-lbs
    2) Shock link plate nuts - 31 ft-lbs
    Hey puma - I think this will take care of you.
    Good luck,
    MD
  5. Puma Cat
    Puma Cat New Member
    East Bay, CA
    Thanks, MD....Reg helped me out, too! Now I just have to figure out which shock link nut of the three is the 43 ft-lb one...I'm thinking it's the one that holds the shock iink plate to the dogbone link...
    Cheers,
    PC
  6. mello dude
    You got it....
    MD
