5th Gen VFR800 No response from Fuel Pump.
Discussion in 'Mechanics Garage' started by Kan'ichirō Yoshimura, Mar 29, 2019.
  1. Kan'ichirō Yoshimura
    Kan'ichirō Yoshimura New Member
    Quebec, Canada
    Hi Guys, I have a Vfr800 2000 and I didn't start it since last summer. I tried today and my Battery was fully charged and everything seems perfect but no response from the fuel pump, the motorcycle won't start. What should I do first to adress this problem. Thank you.
  2. Darth Vader
    Darth Vader New Member
    melton mowbray
    Kill switch on right handlebar .
    Kan'ichirō Yoshimura and Thumbs like this.
  3. squirrelman
    find and check the pump fuse, inspect wiring, study the factory manual.
    Kan'ichirō Yoshimura likes this.
  4. Kan'ichirō Yoshimura
    Quebec, Canada
    Thanks yes I downloaded the manual. Check the fuse and connection but I still doesn't found what's the problem. My last step is to see with a voltmeter if there is juice going through the fuel pump connector. After that I'll take out the fuel pump and see if I have to pronounce her dead.
  5. Kan'ichirō Yoshimura
    Quebec, Canada
    Thank you. The kill switch is already being ruled out of the equation. It's something else. I wish it was that easy.
