5th Gen Wheel Swap
Discussion in '5th Generation 1998-2001' started by mark641, Aug 1, 2015.
  1. mark641
    mark641 New Member
    RAINTON, NORTH YORKSHIRE
    Anyone know if a 2004 V-TEC rear wheel will fit a 5th gen '99 bike?
    Thank you please.
  2. Rollin_Again
    Rollin_Again Member
    Duluth, GA
    Yes 5th and 6th Gen wheels are interchangeable
  3. vfrcapn
    vfrcapn Member
    Grass Valley, CA
    Will the 6th gen wheel work with the gear driven cams?
  4. nookiaz
    nookiaz New Member
    Denmark
    Montreal
    I think it's called "sprocket" :)
  5. TNRabbit
    TNRabbit New Member
    Woodford, VA
    Don't feed the troll~
  6. vfrcapn
    vfrcapn Member
    Grass Valley, CA
    Jeesh man, there's 500 threads on the '98-'10 wheels being the same part number other than color. Do a search.
  7. mark641
    mark641 New Member
    Cool it cpan...I only asked!
  8. OOTV
    OOTV Member
    Maybe this will make up for it...All of the older generation 4 bolt single sided mounted wheels will fit on the newer generations, but not the other way around (I believe that these are all 100mm bolt pattern). The older hubs have protruding retaining bolts that will not allow the newer wheels to sit flush as the newer wheels do not have notches for these bolts to fit into. The 5 and 6 Gen wheels are like the ones in the bottom two photos.
    Like so.
    Older Wheel...
    Newer Wheel...
  9. mark641
    mark641 New Member
    Thank you...that's more like it!
    Quite handy having all those years to pick from. All 180/55 17 fitment as well I take it?
  10. OOTV
    OOTV Member
    I'm pretty sure that the 4 Gen is actually a 5" width wheel and came with a 170 rear tire, but the others are 5.5" width wheels, so 180 rear tire would be correct.
  11. mark641
    mark641 New Member
    It was 5th gen onwards that I was interested with the flush inside face and the wider rim.
    I have a black 5th with black wheels...too much black!
    Will paint mine silver or swap my black ones for silver if anyone wants to?
  12. RVFR
  13. Spensersdad
    Spensersdad New Member
    Northern California... way northern
    Polished wheels would look nice on a black bike. That's a lot of work though!
  14. mark641
    mark641 New Member
    Thanks for the suggestion but polished rims just looks dated and polishing the whole wheel is just too much work and not the custom bike look I'm after. They'll either stay black or I'll find a shade of dark silver that I like and go with that
  15. vfrcapn
    vfrcapn Member
    Grass Valley, CA
    Next pint is on me sir. :black_eyed:
  16. revguy
    revguy New Member
    North Bay Ontario
    It might not as they are directly related lol
  17. revguy
    revguy New Member
    North Bay Ontario
    you may have to adjust your mirrors to make them work
  18. mark641
    mark641 New Member
    Make it so Capnvfr...am in Leesburg VA mid September for a charity ride in aid of a children's hospital
    Chhers!
  19. VFRIRL
    VFRIRL New Member
    Ireland
    Ireland
    So all wheels from 6th gen vtec range will fit my 5th gen? wouldn't mind going for the silver colour myself.
  20. mello dude
    Romania
    Yes......
    VFRIRL likes this.
