6th Gen Chain indicator...
Discussion in 'New Riders' started by Junyr, Feb 23, 2010.
  1. Junyr
    Junyr New Member
    Des Moines, Iowa, United States
    So I see the sticker with the "New/Replace" down near the rear sprocket. I read the service manual and if I recall correctly it says there's a reference mark to use with that sticker but for the life of me I can't locate waht they're talkign about. So what is it I'm looking for to use in conjunction with this indicator sticker for chain stretch?
  2. Junyr
    Junyr New Member
    NVM, I think I got it. the indicator is where the rear sprocket teeth line up with the indicator... *swoosh*
  3. 02 VFR Rider
    02 VFR Rider New Member
    no clue.... if you can lift you chain off the sprockets then chain and or sprockets are bad..replace, never mind the sticker. Thats what I do
