6th gen fuel tank removal
Discussion in '6th Generation 2002-2013' started by Comicus, May 14, 2010.
  1. Comicus
    Comicus New Member
    East Nashville
    Ok so I'm going to do the pair valve removal and after doing some searches it seems it would be easiest to remove the fuel tank. My question is how? I've propped up the fuel tank to replace the air filter so I assume if I just remove the two bolts at the rear of the tank I should be able to remove the entire tank. Any advice on the tank removal, draining the fuel, or the pair valve mod in general would be greatly appreciated.
    Thanks:cheersaf:
  2. 02 VFR Rider
    02 VFR Rider New Member
    I did mine and did not have to remove the tank, just prob it up and remove the air box, the rear you can get at with the seat off and tank back in place.
  3. tsiah
    tsiah New Member
    Why remove the valve? What's the advantage? Seems like hype to me...like removing EGR.
    Sent from my T-Mobile G1 using Tapatalk
