6th Gen headlight failure.
Discussion in 'Mechanics Garage' started by RodC, Oct 7, 2023.
  1. RodC
    RodC New Member
    Toronto
    They just stopped working.
    I have an '08 interceptor and it runs pretty well. Rode from Hamilton to Calgary and back 2 months ago without issue. Was riding it a couple of days ago and I realized that the regular headlights weren't working. The High beams no problem, just the regular running ones.
    Any suggestion as to what might be the issue?
    All the other lights seem to work without issue.
  2. Grum
    Grum New Member
    Quite often this is caused by faulty auxiliary contacts of the Starter Switch, However this will disable Both Hi and Lo beams, so not really applicable in your situation as your Hi Beams are fine.
    Have you confirmed that Both Lo beam glodes are good, and not blown?
  3. RodC
    RodC New Member
    Toronto
    I looked at them, but haven't taken them out as it's a real pain. Probably tomorrow.
  4. Grum
    Grum New Member
    The other option is to measure each globe socket between the White/Black and Green wire to ensure you are seeing 12v. If you Do measure 12v then there is a good chance the globes are blown.
    If you Don't measure 12v then you need the make sure the Green Ground wire is properly Grounded and that the Lo Beam relay is switching the 12v of the Red/Black wire through to the globes on the White/Black wire.
  5. RodC
    RodC New Member
    Toronto
    Thanks for the info. I'll try checking the power. I think there may be other issues as the previous owner installed a GPS which up to now has been working well, but recently has started cutting out.
  6. One Ida 31
    One Ida 31 New Member
    Visalia in the People's Republic of Kalifornia
    Before you start getting all scientific and ripping into things, switch your high beam relay with the low beam relay and see if that is likely the issue. If so, it's a simple fix. https://www.amazon.com/dp/B01DIL2PUA?psc=1&ref=ppx_yo2ov_dt_b_product_details I know it says it's a starter relay, but it works just fine on my '99.
  7. Flyboyohio
    Flyboyohio New Member
    This just happened to me too. Where are the relays located??
