6th gen motor knock
Discussion in 'Mechanics Garage' started by bmoryungn, May 21, 2016.
  1. bmoryungn
    bmoryungn New Member
    hey guys I have a 2004 vfr 800, it has a crazy motor knock going on. some people are telling me that it's the cam chain tensioner. I'm not sure what it is, if anyone could help me out id appreciate it.
    https://youtu.be/nW0lt97sC4c
  2. bmoryungn
    the bike has 50,000 miles on it too
  3. 34468 Randy
    I can't access that clip on my phone but cam chain tensioners do cause a knockng sound. Mine were done right aboit the same mileage as what you have now.
  4. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
    Does it go away / get quieter once the bike is warmed up? If so, then likely the cam chain tensioners.
    Have the valves clearances been checked / done?
    Any loss of power? Oil level staying the same? Smell like fuel? Hard to start?
  5. bmoryungn
    the sound goes away when I'm riding it only knocks sometimes, the oil is the same all the time it does smell like gas sometimes and no loss in power. I haven't had anything checked yet they want 600 just to check it.
  6. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
    $600 to check it? Wow. They must be pulling all the covers off - is that price including new seals / gaskets?
    Sounds like tensioners to me.
  7. bmoryungn
    no that's just to check it. if you type in aarron Myers into YouTube the video should pop up
  8. bmoryungn
    try vfr 800 knock help
  9. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
    I watched your video. Again, I think it's likely the cam chain tensioners.
  10. bmoryungn
    ok I'll look into prices to get that fixed. is it a hard fix to do it myself? I'm really good at working on cars I don't have much experience with motorcycles.
  11. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
    If you're mechanically inclined as you say you are, it's pretty easy - just takes some time.
  12. bmoryungn
    ok thank you I'll order the parts next week!
  13. Expvet
    Expvet New Member
    Puerto Rico
    Brooklyn, NY
    There is a good How To on VFRD that shows you step by step how to change them without throttle body removal, which is the majority of the PITA labor if you go by the service manual. The rear one is very easy, do that one first and you will be familiar with doing the front one. An hour to two max. Order the mandatory 2 cover bolt washers and an extra mounting and cap bolt to be safe.
