6th Gen Turn Signals and Horn Not Working
Discussion in 'Introductions' started by sltaylor13, Jun 17, 2013.
  1. sltaylor13
    sltaylor13 New Member
    Recently picked up an '08 VFR at an auction. Bike had been laid down and needed minor work to be brought back to life. Only glaring problem now as I put it back together is the fact that [/Ithe turn signals and horn do not work. I have checked the fuse. Have not tested any wires. First road bike that I have owned. Would appreciate any help.
  2. derstuka
    San Diego, CA
    Hello and welcome boss! Make yerself at home! Post your problem in the sixth gen forum for a better response.
    Long, Bryan.....stop yer slackin'....come and take your lashings from Helga. :xxx::ass:
  3. tinkerinWstuff
    there's an electrical connector behind the dash that handles the left side controls. My guess is that your high beams aren't working either.
    follow the electrical wire bundle from the left side grip and check the connector.
  4. Scubalong
    Sorry for the late response Taylor :sad:
    :welcome: to the madness, sorry about your electrical issue. Have you pull out all the fuses to make sure they are in working condition. I know you said you check the fuses but not sure if you actually pull them out. One of the member here having similar issue after couple weeks of frustration he pull all the fuses out to have a look and one of the fuse were badly corrosed.....:crazy:
