7 or 8 wire Regulator/Retifier
Discussion in '5th Generation 1998-2001' started by slowbird, Jun 25, 2016.
  1. slowbird
    slowbird Member
    Toronto, Ontario.
    Long story short my battery went flat on me. Wasn't holding a charge. Got a fresh one and doing the different tests a.k.a "The Drill" showed the battery wasn't charging.
    Swapped the "new" Ricks R/R that the previous owner had on it with the old one he was kind enough to supply with the bike and the bike is charging fine now.
    However I noticed the "Ricks" R/R has 1 less wire and connector than the working R/R and the VFRness that it plugs into.
    Can anyone shed any light on this? Why there is a 7 and an 8 wire R/R?
    Did the previous owner slap on the wrong R/R?
    Here is the supposed "Ricks" reg which I removed and noticed the 1 missing connection:
    The old one I put back on and is working fine now. It has 5 wires in the connector where the other R/R only has 4:
  2. slowbird
    slowbird Member
    Toronto, Ontario.
    I'm doing some more research and I think maybe the 7 wire regulator (3 yellow stator wires and 4 others) are for the 1998-1999 VFR800, and the 8 wire regulator (3 yellow stator wires and 5 others) are for the 2000-2001 VFR800?
    :cower:
  3. Terry Smith
    New Zealand
    The 98-01 service manual only has a single diagram and the RR has 4 wire outputs. The 6th gen has 5 outputs.
  4. slowbird
    slowbird Member
    Toronto, Ontario.
    I noticed that aswell, however Honda lists different part numbers for the 98-99 and the 00-01.
    I think I read somewhere that in 2000 they added some kind of accessory wire monitor and that is where the 5th wire comes into play.
