83' Right Hand Control
Discussion in '1st & 2nd Generation 1983-1989' started by itzwitz, Jul 10, 2008.
  1. itzwitz
    itzwitz New Member
    The start button on my right hand control does not spring back so I have to manually disengage the stator. I would buy a new one, but the right hand control switch for an 83' is unavailable. Does anyone know if the 84' VF750F(35130-MF2-P00) is wired the same way as it was in 83' and would work with no modifications?
  2. GreyVF750F
    GreyVF750F Member
    West of Cleveland Ohio
    yep it's the same. there are several on e-bay now
  3. Lgn001
    Lgn001 Member
    Russian River by Ocean, CA
    It seems to me that I have repaired at least one starter switch somewhere in my past. They are really nothing more than two contact points, a "wiper" of sorts that connects the contact points, and a small spring. They are a bit delicate, but nothing horrible. I seem to remember a ball point pen donating it's spring as a replacement item.
    Just something to think about before you throw it away.
  4. itzwitz
    itzwitz New Member
    Thanks for the response and I'll look on e-bay tonight.
  5. itzwitz
    itzwitz New Member
    I have to non-working spring related right hand controls that I will play around with. Thanks for the response.
  6. 859-kentucky-blue
    859-kentucky-blue New Member
    these right hand controls are around to replace what you have-- you will find numerous left hand switches but the right one is the hardest and most expensive. I also have contacts for this part and any other parts needed- they are not real cheap, but obtainable and the issues with this part is the start button will break everything else remains good in the control. I have an 83 it is the red one the blue is the harder one to find parts for- this part for the 83 is a 1 year part, no other years or models will work for it- make certain of the main plug configuration, know exactly what you are looking for to avoid issues- I learned the hard way; so I know what I am saying. it will be a red plug, 9 pin with 7 wires and no jump wire in the plug---I have spent numerous hours in research and buying parts for my bike..if u need help, holla !!!.
  7. 74ullc
    74ullc New Member
    Gulf Coast, Texas
    It's been over 6 yrs and he never posted again. He probably has it worked out by now.
