83 vf750f needs rebuild help!!!!!!!!!!!!!!!
Discussion in 'Introductions' started by kjrs83vf750, Nov 10, 2010.
  1. kjrs83vf750
    kjrs83vf750 New Member
    San Jose, CA
    I recently bought an 83 vf750f it's been to the shop twice in 2 months, now i'm told it has no compression in the #4 after it was backfiring out the right tail pipe. The bike has 15,000 mi on it norris cam's, and kerker pipes. Do I part it out, rebuild it, used engine?????????? Help!!!!!!!!!!!!!!!!!!!!!!!!!
  2. TOE CUTTER
    That sucks. My money is on a valve issue and they are almost always pretty bad. You need to look into the failure to move on. If it has wadded a valve I would look for a new engine or a complete bike that runs but has been trashed, easy to find. Good luck.
  3. tinkerinWstuff
    leak down test to see what isn't sealing. As TOE said, probably valve.
    Leak-down tester - Wikipedia, the free encyclopedia
    can use a compression tester but plug in an air compressor air hose and listen to where the leakage is. Would think a shop worth it's salt would have taken 2 more minutes to figure it out and tell you what the problem is.
  4. GreyVF750F
    GreyVF750F Member
    West of Cleveland Ohio
    I'd be interested in helping and or the bike/parts if you are not going to proceed to fix. Where are you located?
  5. kjrs83vf750
    San Jose, CA
    83vf750f
    I live in san jose, ca. The shop told me that the #4 cylinder has no compression, and the # 2 cylinder has a cross threaded spark plug......... I just bought the bike 2 mnths ago, it seemed to run alright at the time, but started to backfire out the right tail pipe, then this. It had the cam's replaced with norris cams, kerker exhaust, etc. Where could I find a used engine at a reasonable price, or part it out.
  6. tinkerinWstuff
    lots of used engines and parts bikes come up cheap on Craigslist. You live in the mecha of cheap bikes. Patience will be your friend and daily checks of CL
  7. Davis5g
    Davis5g New Member
    Pittsburgh, PA
    Sounds like the previous owner didn't adjust the valves right after putting in the new cam and burned the exhaust valve on the #4 cylinder from the valve being too tight and not sealing. If thats the case you might be able to get away with a new valve, a valve seat grind, and the gaskets required to reassemble after the work.
  8. tinkerinWstuff
    running motor from craigslist $200.
    fuck around with valve job, helicoil, gasket kit (and done at a shop rate of $75/hr if your lucky) $1500 maybe?
  9. TOE CUTTER
    I did not realize you were so close. I bought a gen 1 engine last year oot of a crash so I assumed it was a runner, sitting on my garage floor. Will let it go cheap. I does not have cams in it and most of the electrical. I will check it oot better if you are interested. I gave 80 bucks for it and will let it go for that and a twelve pack.
  10. squirrelman
    What were you thinkin buying such an old bike ??
    Find something newer on CL, cuz there are lots of other problems that could ruin your VF project.
    Unless you can do all the repair work yourself, it makes no financial sense owning a troublesome, worn out old slapper when you could find something newer and more reliable.
    So you got it cheap??? That should have been a clue.
    If the Mother Theresa of VFRs (TC) wants to help, you're in good hands, but it still would be best to find another bike.
  11. tinkerinWstuff
    I vote TC should show up to SLO next year in a nun outfit
  12. TOE CUTTER
    Porn shot
    I was wondering when Squirrel was gonna chime in. Can't believe this thread has gotten to this point withoot a demand for a pic.......but...lets have a pic of the beast!
    :worthless:
