84 sabre dies when put in gear
Discussion in '1st & 2nd Generation 1983-1989' started by webjoe, Jan 9, 2010.
  1. webjoe
    webjoe New Member
    Hoping someone can help me. I have an 84 honda sabre that starts and idles fine. However, when I put it in 1st gear, holding the clutch in, it jumps and dies. Any help is appreciated on solving the problem. Thanks.
  2. karazy
    karazy New Member
    Halifax, Nova Scotia, Canada
    It sounds like your clutch is not working. The symptoms are the same as if you didn't pull the clutch at all.
    :crazy:
  3. matt1986vf500f
    matt1986vf500f New Member
    Lula, Georgia, United States
    does the clutch master cylinder have any fuild in it? try bleeding the system if that does it help you might have to pull the side cover and check out the clutch
  4. webjoe
    webjoe New Member
    So do I have to replace everything or just the friction plates? Thanks.
  5. horseiron1
    horseiron1 New Member
    North Louisiana
    you have to make sure its the actual clutch or just the slave cylinder or clutch master cylinder, low on fluid and got air in the lines.
  6. webjoe
    webjoe New Member
    Ok. Well I bled it, and when I pulled the handle to engage the clutch, fluid came out the open line, so I am thinking that part is fine. So I know that there is fluid making it down there. What would be my next step then? I appreciate all the help guys!
  7. matt1986vf500f
    ok so fuild is making its way to the clutch slave cylinder, pull your clutch cover off and see if its engaging the clutch, the plates should become loose when the clutch lever is pulled.
  8. jev.
    jev. over there
    Has the bike been sitting a while? It sounds like the plates are sticking.
  9. bluespecv03
    bluespecv03 New Member
    Daytona Beach, FL
    Does it have a kickstand switch?
  10. matt1986vf500f
    i would'nt think so it being a 84, but thats a good question
