'84 VF1000F throttle issue
Discussion in '1st & 2nd Generation 1983-1989' started by puckstopper, May 24, 2011.
  1. puckstopper
    puckstopper New Member
    Hey Gents
    After replacing the head gaskets I've got the old girl all back together but I have one final issue. She starts really well on choke and will idle on choke but if I give it any kind of throttle it dies. Also dies if I take off the choke. Anyone had similar experience?
    thanks as always fellas
  2. jafo
    jafo New Member
    Ithaca NY
    did you readjust valves or check clearances??
    have you rechecked your compression?
    is backfiring or spitting and sputtering ? anymore info you can give will help.:smile:
  3. puckstopper
    Tks for the reply. Did the valve clearances and all is back together. Seems to run fine on choke but as soon as I take choke off or they to add throttle she dies. Didn't do compression test
  4. GreyVF750F
    GreyVF750F Member
    West of Cleveland Ohio
    Adjusted the pilot screws and idle screw properly? Can you get motor up to temp and then see what happens?
