'85 VF500F Gearshift Linkage Stiff
Discussion in '1st & 2nd Generation 1983-1989' started by dustin033, Apr 9, 2015.
  1. dustin033
    dustin033 New Member
    I'm in the process of putting the engine back in my '85 VF500F. It is now back in the frame, and I ran it through all of the gears. That seemed okay, but the gearshift lever doesn't pop back up or down after shifting. Is this a sign of an assembly error in the gearshift linkage, or is this likely because I'm in the process of reassembling and everything isn't lubricated well yet?
  2. jeremyr62
    jeremyr62 New Member
    Ireland
    Limerick, Ireland
    That's a question only you can answer methinks.
  3. Lobotomy
    Lobotomy New Member
    Toronto Ontario
    There is a return spring on the gearshift spindle, Check to see if it is back on properly. It is section 8-5 in
    the service manual.
  4. squirrelman
    OMG, an ASSembly error, ya gitty pillock !
    If the engine is running, shifting stiffness is most often due to failure of the clutch to fully release: air in lines, low or bad fluid, etc.
  5. dustin033
    The engine is not yet running. I was simply looking for some pointers before pulling the subframe and water pump back off...
  6. dustin033
    I took it apart and found that all of the gears weren't quite lined up. It seems better now.
